Old 05-07-2011, 11:51 PM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Painting seal off?
Alright so I bought some vht-night shades (tinting my real tail lights)
So I have
Sand Paper
Masking Tape
Tail tinting spray
Clear spray paint (for after the tint)
Now the thing is I need something to keep the paint off the body so I bought gift wrapping tissue paper, but I fear the paint will go through it so I needed something else to seal off I was gonna get poster paper but it is way too thick and not flexible for shaping around.
Any tips are appreciated or some sort of paper/material to use as a cover.
Old 05-08-2011, 03:56 AM   #2
Um, why don't you just take the lights off?
Old 05-08-2011, 01:50 PM   #3
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Dunno how and scared of screwing it up lol
Old 05-08-2011, 03:08 PM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Dude you are telling me you don't know how to remove ur tailights?
There is nothing you can fuck up
Oh and you won't need sand paper for the tails if what ur using is night shade
Originally Posted by sw07gt
Old 05-08-2011, 03:28 PM   #5
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Tried there is a white tri-pin that no idea if I push out or in.
Then there are two more pins lower white and black with rubber on them or something but I did not touch those.
Old 05-08-2011, 03:43 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
You can go to any office supply store and buy brown paper on a roll that is used for wrapping packages.
Old 05-08-2011, 06:50 PM   #7
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
There are two or three 10mm(IIRC) bolts on the backside(inside the hatch) of the taillights. Open the lamp access cover, remove the bolts, then push/pull the lights out.
The VHT requires little prep, rub the entire light down with rubbing alcohol, then go to work. One thing to remember is it's really difficult to remove the VHT once you put it on, even after a only a few seconds...if you screw up get it off IMMEDIATELY, but it still won't look good as new. Also, it gets dark real fast if you go more than one coat. I planned on doing a very light smoke, one came out perfect, the other had a spot of grease or something on it so I had to clean it off and start over...long story short I had to do more than one coat and now I have super black tailghts(which I'm fine with) but it wasn't my ultimate goal.
-Type 07 FFL-
My odometer 03/11
Old 05-09-2011, 03:39 PM   #8
.Kevin.
I ain't even mad
.Kevin.'s Avatar
It is done there is a VERY minor MINOR tape spray that somehow got through but it is really unnoticeable. The lights themselves came out decently did my friends aswell didn't even take them off looks beatiful,
Old 05-10-2011, 04:48 AM   #9
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Pics??
rye7jen is offline   Reply With Quote
Old 05-10-2011, 01:32 PM   #10
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Didnt get much from the prep but will take some after photos!
Old 05-10-2011, 01:40 PM   #11
RedRide
RedRide's Avatar
All you need is some ol' fashioned newspaper to mask off areas.
Old 05-10-2011, 06:45 PM   #12
.Kevin.
I ain't even mad
.Kevin.'s Avatar
No removal, masking tape with newspaper here ya go.
File Type: jpg 225313_10150237168989083_641929082_8746940_5731278_n.jpg (59.3 KB, 26 views)
blown axle seal ! alfmoonspace DIY / Maintenance / Service 22 09-19-2010 08:58 PM
Hood Seal Kit SaerinRhoe General Yaris / Vitz Discussion 6 09-13-2009 09:32 PM
Garm's hood seal install RedRide Cosmetic Modifications (Exterior/Interior) 22 08-26-2009 03:05 PM
Painting... naossoan Cosmetic Modifications (Exterior/Interior) 9 05-17-2009 11:25 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
