Old 05-11-2011, 08:21 AM   #1
SWL
Yaris not starting after major engine repair
My daughter drove her 2007 Yaris hot (three times) and warped the head - Being an old shade tree mechanic I thought I would save her some money and do the job myself. I tore it down had the head resurfaced and reworked and put it all back together carefully, following the online yaris service manual step by step - Now I cannot get any fire to the ignition - It does NOT have the engine immobilzation system ( it was an option in 2007 in US) - I have checked the sensors (Crankcase, camshaft positioning sensors) and they fall within specs - I asked a local mechanic and he thought that my ECU needed reprogramming by the dealer - Is this possible? I can find no mention of it in the service manual online. What else could keep me from getting fire to the plugs? I checked the ECU fuses - all ok - checked the harness - all ok - the car was running (badly) when it tore it down - I'm at my wit's end. Any advice would be appreciated.
SWL is offline   Reply With Quote
Old 05-11-2011, 09:55 AM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Are you getting electricity ?
Originally Posted by sw07gt
Old 05-11-2011, 09:56 AM   #3
The ECU definitely doesn't need reprogramming. Do you have an OBDII code reader that you can plug in to make sure that the ECM is actually alive?
Old 05-11-2011, 11:23 AM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Might be silly but.. is the battery still alive?
Old 05-12-2011, 09:07 AM   #5
SWL
yes to all
Thanks for the posts! I do have a reader and the ECU is alive - I am getting electricity to the places I am supposed to .... except the plugs - It spins like a tops but never hits - I took out the plugs and followed the service manual procedure for testing for fire to the plugs - no spark - these are new irridium plugs ($8 each!) I have gone so far as to take a volt/ohm meter and check the ecu and harness to make sure that the pins that go to the various parts of the ignition system are alive and they are.... I guess I am going to have to have it towed to a dealer. Thanks for the input!
Old 05-12-2011, 09:13 AM   #6
Check the AM2 fuse in the under hood fuse panel.
Old 05-12-2011, 12:17 PM   #7
Hershey
Hmmmmmmmm .Timing off ?
Old 05-12-2011, 03:03 PM   #8
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
How is the ignition triggered in our motors?
Could the cams be 180* out of phase with the crank/ignition?
Old 05-14-2011, 02:32 AM   #9
p123456789
Drives: 07 lb jeep tj
scan for codes and go from there.
p123456789 is offline   Reply With Quote
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
