Old 05-22-2011, 02:09 PM   #1
spolice973
Drives: 2007 Toyota Yaris HB
Exclamation Yaris battery light on...why??
took it to autozone, but we can't determine the cold cranking amps on the battery. i have a 2007 yaris hb, since 2006 (about 105k miles on it). the car starts, the radio runs, the lights work fine, but the battery light is on (red - which indicates to go to dealer - which is closed today, of course). how can the light be on but the car runs fine? does anyone know the cc amps on the original battery? not in manual, on their website or anywhere! amazing, i've found the one thing google can't find!
thanks...
spolice973 is offline   Reply With Quote
Old 05-22-2011, 02:19 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
normally, that light only comes on when one of three things is bad... target the battery, should be ~500cca IIRC... the second option is to check the alternator... third is to check your battery connections for corrosion... one other possibility, that autozone people might miss, is the serpentine belt there?
i like this smiley...
silver_echo is offline   Reply With Quote
Old 05-22-2011, 02:19 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Maybe your alternator is having a problem.
Old 05-22-2011, 02:22 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i didn't even know there was a battery light. That is just weird.
Colin Chapman disciple
Old 05-22-2011, 02:24 PM   #5
silver_echo
ekodrvr
all cars that i have ever come across have one... comes on when you first turn the car on, then turns off when the alt. picks up...
Old 05-22-2011, 02:25 PM   #6
There's a known/common problem with 07-08's with the voltage regulator within the alternator corroding and casing the light to come on.
Old 05-22-2011, 02:27 PM   #7
BLH
Drives: 2007 Yaris Sedan
Here is the TSB for the 2007.
http://www.etimago.com/yaris/TSB/T-E...t%20ON%20).pdf
Old 05-22-2011, 02:28 PM   #8
silver_echo
ekodrvr
another very likely answer... and one that i will bank on as scott does more with yaris than i do...
go with scott's answer for the time being, and if that is not it, then we follow the trouble tree...
Old 05-22-2011, 02:31 PM   #9
spolice973
Question ok...thanks...
i dont plan to drive it anymore today...and my mechanic, thankfully, is half block away. i will have to go first thing in AM. even though autozone does free testing, i'm afraid to drive it back there (a couple miles away) and have it conk out on me.
Old 05-22-2011, 02:36 PM   #10
silver_echo
ekodrvr
i would mention the TSB about the voltage regulator to the mechanic... might save him some time...
Old 05-22-2011, 02:45 PM   #11
spolice973
Question yup, already wrote that down
i also plan to ask him why this wasn't seen (if it is indeed corrosion) when i had my 100k tune up
Old 05-22-2011, 02:49 PM   #12
He would only have seen it if he completely disassembled the alternator. There's a thread on here where I posted pictures of one completely disassembled.
Old 05-22-2011, 03:04 PM   #13
spolice973
Unhappy
ok...thank you for saying that b/c i like this guy and i'd hate to think he's screwing me over or missing things! ok, so i will be nice :)
i'll report back in the afternoon with any findings...i hope i can drive it to work- shoot!
Old 05-22-2011, 03:13 PM   #14
I've been dealing with this for nearly 3 years with my '06.
Whenever there is a heavy rainfall, or very dense fog, my battery light comes on. It willl always go out again when conditions dry up. I have a spare alternator on stand-by just waiting for the day the voltage regulator finally gives up for good. Had the spare for almost a year now but the original just wont die.
BTW, is your light on solid, or does it flicker? Mine flilckers. If it is on solid, then you may actually have another issue other than the regulator.
Old 05-23-2011, 10:24 PM   #15
Thegg
Drives: Polar White Liftback
I have the same car and the same issue. I'm pretty certain that it's the Voltage Regulator. Can anyone recommend a good site to order from?
Thegg is offline   Reply With Quote
cold cranking amps, yaris 2007
Yaris sedan fog light bezels SimTronik Willing to Buy by private party 0 10-01-2010 04:49 PM
Rear fog light for US '08 3Door Yaris (stick shift9 Stefan DIY / Maintenance / Service 21 04-21-2010 04:30 PM
