Old 05-23-2011, 05:15 PM   #1
danno7263
Drives: 2008 Yaris
Dome/Floor Light and Headlights on Warning Not Working
Sorry for the totally rookie question, but when I have my lights on, turn off the car, take the keys out and open the door, I don't get a warning that the lights are still on which is a huge pain. Also, when I open the door, the interior lights don't come on (yes, I have the switch on the dome set to "door").
Any suggestions???
danno7263 is offline   Reply With Quote
Old 05-23-2011, 06:51 PM   #2
gabecham
gabecham's Avatar
Drives: 09 yaris sedan
Do they turn on at all, might be a fuse....just a thought
gabecham is offline   Reply With Quote
Old 05-23-2011, 07:42 PM   #3
BLH
Drives: 2007 Yaris Sedan
Do any of the doors turn it on?
Will it go on if you set it to the manually on position instead of the door position?
Old 05-24-2011, 09:50 AM   #4
danno7263
Drives: 2008 Yaris
It goes on when I turn it on and I checked the fuses, nothing seemed out. Like I said, the warning buzzer that sounds if you leave your lights on doesn't go off either, which is a huge pain!!
Old 05-24-2011, 10:35 AM   #5
The switch on the door frame may be damaged, since they work in manual mode.
headlights not working.... Judas Iscariot DIY / Maintenance / Service 66 09-05-2019 11:27 PM
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
