Old 05-24-2011, 10:29 AM   #1
HerYarisNotMine
Drives: '07 Yaris Hatchback
Serpentine belt broken with oil on it
My battery light came on last night. This morning I popped my hood to see that my serpentine belt was broken and there was oil on one of the ribs. There is some black oil on the side of the engine about midway down. My engine oil isn't black, it's more like a yellowish brown.
Any ideas as to the source of the oil before I call a tow truck?
07 HB btw
HerYarisNotMine is offline   Reply With Quote
Old 05-24-2011, 10:32 AM   #2
Maybe it whacked something else when it snapped and came loose. Check the CV joint boots on the passenger side to make sure that it didn't whip and tear one, picking up the grease from inside of the boot.
Old 05-24-2011, 10:58 AM   #3
Klink10
Klink10's Avatar
Good call there CT. I would have checked oil level at the dipstick then looked elsewhere as in where you stated.
Old 05-24-2011, 11:08 AM   #4
HerYarisNotMine
The rubber cover on top of the motor mount was chewed by a racoon more than a year ago, and it has been sort of half assed covered with some plastic covering. It would appear that the source of the oil is the motor mount, I believe the Yaris uses hydraulic fluid in these mounts correct?
So my guess is that the motor mount failed and must be replaced. What do you think?
Engine oil level is fine, same level it was at yesterday when I checked it. I will go look at the CV boots, but I don't think that's where it's coming from.
Old 05-24-2011, 11:27 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
pictures would be very helpful
Old 05-24-2011, 11:57 AM   #6
HerYarisNotMine
I'm having the car towed to a shop I'll let you know what they say.
Old 05-25-2011, 09:58 AM   #7
HerYarisNotMine
As I suspected, the oil was from the busted motor mount. It will have to be replaced along with the serpentine belt.
The bearings on my water pump are also shot and it will need to be replaced. The most likely cause is when I tightened the serpentine belt myself and did not check the tension, which put too much strain on the bearings.
WARNING TO ANYONE WHO FINDS THIS THREAD
DO NOT TENSION YOUR OWN SERPENTINE BELT UNLESS YOU HAVE A TOOL TO VERIFY CORRECT TENSION.
Old 05-31-2011, 02:40 PM   #8
brooklynyaris
Drives: stock
hi i was reading your blog and i have a question. i have an 08 w/65k on it and it just lost the belt this morning. what is the pully belong to that is under the ALT. i have looked online for a diagram and called a few parts stores and they dont know the layout. i didnt really look because i was late for work.. H E L P please
brooklynyaris is offline   Reply With Quote
Old 05-31-2011, 02:44 PM   #9
That's the AC compressor or water pump. There are just two belt types for the 06-11 USDM Yaris; One for ones with AC and one for ones without.
Old 05-31-2011, 02:46 PM   #10
Old 05-31-2011, 02:51 PM   #11
brooklynyaris
Drives: stock
thanks ctscott..
Altenator Belt Broken After Replaced by Toyota Yaris_guy DIY / Maintenance / Service 12 01-18-2011 09:14 PM
