Old 06-01-2011, 10:22 PM   #1
bigapl
Drives: 2010 Yaris
Hot weather cooling
I am looking to see if anyone in the south has looked into a thermo switch, a battery, a diode, a timer, and solar panel to power the hvac fan on hot days to circulate the fan. I was looking into placing a panel on the rear shelf of a hatchback and have it charge a small 12volt battery once the inside temp hits 100deg for like 5 minutes then shut off for 15 minutes and cycle 5 15.
bigapl is offline   Reply With Quote
Old 06-01-2011, 10:37 PM   #2
You'd need a mighty large solar panel or a short duty cycle. The HVAC fan draws about 3 Amps.
Old 06-01-2011, 11:14 PM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
What about wiring the car's battery to do this? Install a switch that enables this mode so that it only activates when you want it to? Would be dreadfully complicated though.
Old 06-02-2011, 08:51 AM   #4
With tinted windows and a reflective windshield cover you can cut down DRASTICALLY the inside temp of the car on a sunny day.
Old 06-02-2011, 08:51 AM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
http://e-solarproducts.com/Solar-Cooling-Fan.html
Old 06-02-2011, 11:31 AM   #6
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
^ does anyone actually own one and could provide a quick review?
Old 06-02-2011, 11:51 AM   #7
toy_toronto
always toyin'
Drives: 2010 5-Dr
nvm. save your money folks:
http://www.amazon.com/Auto-Solar-2dP...sim_dbs_auto_3
-toy
Old 06-03-2011, 08:25 AM   #8
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Originally Posted by toy_toronto View Post
In the customer reviews, 84% said it didn't work (the 1s and 2s).
rick996 is offline   Reply With Quote
Hot key LtNoogie General Yaris / Vitz Discussion 18 05-25-2010 12:33 AM
Summer -vs- Winter ''Hot Key'' TRDMarty General Yaris / Vitz Discussion 2 11-16-2009 01:52 PM
Best synthetic for HOT weather? DFA DIY / Maintenance / Service 31 12-24-2008 12:04 PM
Hot Ticket Toys This Holiday kuyachris84 Off-topic / Other Cars / Everything else Discussions 5 12-17-2008 09:53 PM
underhood weather stripping drifto General Yaris / Vitz Discussion 3 04-18-2007 09:36 PM
