Old 06-02-2011, 05:34 PM   #1
sxekevin
Drives: Blue Yaris Hatchback
Wheels stuck...
I was wondering an easier way to take off the wheels because they seem to be almost pressed on every time I try to take them off.
sxekevin is offline   Reply With Quote
Old 06-02-2011, 06:27 PM   #2
You've done it before, do it once again the same way. Then, before you remount again, apply a coating of grease around the hub. You'll never have an issue again.
Old 06-02-2011, 08:04 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
take off all lug nuts. then put one nut back on half way.. then kick the crap out of it..
Old 06-02-2011, 09:13 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'd add in some wire brush action around the hub if there is corrosion as well.
-Type 07 FFL-
My odometer 03/11
Old 06-03-2011, 12:40 AM   #5
sxekevin
Thanks for the replies. I did take them off once, but then they were even harder the next time to the point in which I had the dealership do it. I will definitely lube up the hub next time.
Old 06-03-2011, 03:31 PM   #6
markitect
Don't waste your time kicking at it. With the lug nuts loosened take the spare tire and use it to give the stuck wheel a good hard whack.
markitect is offline   Reply With Quote
Old 06-05-2011, 02:12 PM   #7
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
I love this method
Rob Cohen called, he needs his altezza's for the next Fast And The Furious
yarislady is offline   Reply With Quote
Rays/Volk TE37 race wheels - 15"x7", 4x100 pattern, w/ NEW Falken Azenis rt615K's ozmdd Items for Sale by private party 5 04-29-2010 12:37 AM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
