Old 06-04-2011, 04:10 PM   #1
thecoltons
Drives: 2007 Yaris Lift Back
Looking at an 07' Yaris LB Any input?
We are looking at purchasing a 2007 model Yaris LB with 81K miles on it. I have a Camry now and have driven a Corolla as well and loved both. The car has a clean Carfax report and is in excellent condition....just needs a good detailing. Are there any mechanical issues that we should be aware of with this model Yaris? Any input would be greatly appreciated!
thecoltons is offline   Reply With Quote
Old 06-05-2011, 05:08 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Not really, no. It is a toyota. The Yaris has been rock solid stable, and no real mass problems of any type have shown up.
Colin Chapman disciple
Old 06-06-2011, 12:53 AM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Ask if the catalytic converter has been changed . There was a recall on the 07 LB .
Old 06-14-2011, 09:43 AM   #4
Alysia
Drives: 2007 Yaris Hatchback LE
I bought an 07 Yaris 5door LE in March and I have had no problems with it
Alysia is offline   Reply With Quote
Old 06-14-2011, 02:45 PM   #5
Klink10
Klink10's Avatar
If your near Fayetteville look me up glad, to talk with you about the Yaris. OR.....take a quik run this way. PM me for arrangements as we are heading to MN to pick up my Norton this weekend.
Old 06-14-2011, 03:18 PM   #6
Find out if the AC evaporator has been replaced. If you do a little searching here for "stink" you will find that 06-08 Yaris can have an issue with the AC really stinking. There is a Toyota service bulletin on the issue (which you'll run into in the AC stink threads).
Old 06-14-2011, 03:39 PM   #7
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
460,000+ miles and counting. Keep a thousand dollars aside and you'll be able to fix(or replace) anything that *might* break. The engine in mine was swapped at 250K(reason unknown) because the repair was more than the cost of a complete replacement(low mileage wrecking yard swap).
-Type 07 FFL-
My odometer 03/11
Old 06-14-2011, 04:47 PM   #8
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
CHECK water pump for leaks....
ROCKLANDTOYOTA is offline   Reply With Quote
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
