Old 06-07-2011, 04:25 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Will this add-on amp. do anything for me?
My head unit's specs. say it has mosfet RMS 50Wx4 amplifier.
I received these speakers for free to replace my stock speakers:
Front:
http://www.crutchfield.com/p_206DS65...er-DS65-2.html
Rear:
http://www.crutchfield.com/p_206DS65/Kicker-DS65.html
My friend is offering me his Alpine KTP-445 Power Pack:
http://www.crutchfield.com/S-R91gAof...ower-Pack.html
He says it'll be better than powering the speakers directly from the head unit.
He can modify the KTP-445 to work with my head unit. I noticed though that the KTP-445's specs. shows it only does RMS 45Wx4.
Will it still be better than powering the speakers directly from the head unit?
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 06-07-2011, 06:53 AM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
Your head unit says 50w x 4 but that is peak power, probably not continuous.The Alpine would probably should better for sure. The head unit would probably run real hot trying to pump out that power too and shorten the life span. I say go with the alpine amp and run RCA cable from head unit to amp and enjoy!
Old 06-07-2011, 07:05 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
The Alpine amp. is a plug and play unit made for Alpine HUs. It can be modified to work with other brands though. I guess I'll go with it.
Heatware:
Old 06-07-2011, 02:00 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Are the 6.75's and tweeters rated together at 6-60 watts or individually ? If individually, you're not gonna be hitting nowhere near the max rms (60 watts) with that amp.
Old 06-07-2011, 11:49 PM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^That being said, a standalone amplifier is MUCH better than a deck "amplifier".
― Thomas Paine
Old 06-08-2011, 12:33 AM   #6
IsLNdbOi
IsLNdbOi's Avatar
Obviously.
I just don't want to go through the trouble of running all those RCA wires and then extending the stock speaker wires to the amp..
Heatware:
Old 06-08-2011, 10:17 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
What shops do you know around LV?
I am closely acquainted with Jon Web and Troy McGregor at Performance Audio. I can tell you that they can work with you on a project like this if you wanted. I could probably pull a discounted rate versus a stranger walking in as well.
― Thomas Paine
Old 06-08-2011, 03:11 PM   #8
_S7V7N_
_S7V7N_'s Avatar
That add-on is saying 45 watts RMS, It'll sound better than the 20 watts RMS your deck is putting out. Here's a thought, Run the tweeter off your stereo and the 6.75 off the add-on, if possible, idk how that thing will be wired in.
Old 06-08-2011, 03:59 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^You could bridge the 4 down to a two channel. You'll probably have around double the power going to the mids in most cases. Watch the level on the tweeters. If you crank the stock deck too much you'll most liekly end up clipping the signal to the tweeters.
― Thomas Paine
Old 06-08-2011, 04:32 PM   #10
IsLNdbOi
IsLNdbOi's Avatar
I don't know any shops in Vegas. I've always installed things myself. I did install a four channel Alpine PDX in my previous car and it was too much work for me.
I went ahead and installed the Z130BT last night and it sounds good to me w/o an amplifier (using my stock speakers still). Dunno how it'll sound with those Kicker speakers.
Heatware:
Old 06-08-2011, 07:11 PM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Well, if you feel the need, let me know. I'll pave the way for you at Performance Audio.
Take some time to visit Troy and Jon if you want to feel them out. Mention that John from Team Hybrids sent you their way.
7035 W. Sahara Ave. Ste 200
Las Vegas, NV 89117
(702) 538-8678
― Thomas Paine
Old 06-08-2011, 07:32 PM   #12
IsLNdbOi
IsLNdbOi's Avatar
Thanks, I'll keep them in mind for when I do decide to add an amp..
Heatware:
Old 06-08-2011, 07:53 PM   #13
_S7V7N_
_S7V7N_'s Avatar
It's gonna power the heck out your factory speakers since they're only like 10 watts RMS. That Pioneer deck is pretty damn good if you ask me, and if you ever want to put in an amp it's pushing 4 Volt preamps. Maybe you'll be surprised and the new speakers you install will sound awesome. Keep us posted.
FS/FT: Eclipse 3650 4 + 1 channel amp yaris2010RS Items for Sale by private party 3 03-11-2011 11:24 AM
Sub and amp for sale TEHxFALLEN V1.2 Items for Sale by private party 34 05-17-2010 09:06 AM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
