Old 06-07-2011, 09:56 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Will these speakers fit?
I received these speakers for free to replace my stock speakers:
Front:
http://www.crutchfield.com/p_206DS65...er-DS65-2.html
Rear:
http://www.crutchfield.com/p_206DS65/Kicker-DS65.html
Both are listed as:
6-3/4" (oversized 6-1/2")
Will they fit in the '09 5-door LB? I'm going to put the components in the front doors and the coax. set in the back doors.
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 06-07-2011, 11:10 AM   #2
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Although there are 6.5" speakers in the front, the hole for them should easily accomidate 6 3/4. I had a lot of extra room around the 6.5s I just put in the front of my car. The rear I'm not sure about, as the sedan (which I drive) has 6x9s in the rear.
Old 06-09-2011, 04:18 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Thanks.
Anyone with a 5-door LB know for sure?
Also, what's the maximum depth the speakers can be w/o getting in the way?
Heatware:
Old 06-10-2011, 02:47 AM   #4
CAyaris
CAyaris's Avatar
Send a message via MSN to CAyaris
anything is possible. For the rear grab some scrap mdf and make some speaker rings...
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 06-17-2011, 01:41 AM   #5
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Whoever gave you those are pretty generous but they make brackets that will make a 6.75 fit in a 6.5 hole, and if the 5 door LB is like the 3 door LB its 5.25 in the rear. Unfortunately those don't fit without modification. Like CAyaris said find some small pieces of MDF and make your brackets to extend it out.
Rob Cohen called, he needs his altezza's for the next Fast And The Furious
yarislady is offline   Reply With Quote
Need some experienced advice about speakers Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 0 06-28-2010 10:18 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
