Old 06-08-2011, 08:15 PM   #1
Jason@SportsCar
Cool New upper mounts
Might have to try a set of these.
http://www.cusco.co.jp/en/parts_prod..._upper_mo.html
Old 06-08-2011, 10:38 PM   #2
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
those look very interesting.
cruz-gsr is offline   Reply With Quote
Old 06-09-2011, 12:47 AM   #3
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Where can you order those from?
Old 06-09-2011, 01:51 AM   #4
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
did you saw the notes?
''designed to be used only with CUSCO ZERO series suspension units only''
yaris 2sz is offline   Reply With Quote
Old 06-09-2011, 05:02 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
PFFT! They just saying that so you buy thier suspension.
How much is 30k yen in dollars now-a-days?
Old 06-09-2011, 12:04 PM   #6
Jason@SportsCar
The press release also says: Centerlock pillowball upper mounts apply to all CUSCO suspension systems with no hassle. Also can be installed on other brands with the use of special nut & collar combination.
I would be surprised if it could not be made to work with other struts. Hell, we were able to fit an inverted mono-tube race shock to the OE mount, just takes a little imagination - in our case a Delrin cutting board was sacrificed to make custom bushings.
The USDM press release that was emailed to me says $400.00, but they are not here yet.
Old 06-09-2011, 12:29 PM   #7
So this is a straight mount, with no adjustability. Looks pretty cool, although adjusting camber on the fly would be pretty cooler.
Old 06-09-2011, 12:38 PM   #8
Jason@SportsCar
I would be happy to just eliminate the play/bind that is in the stock mounts. I hate the way they move up and down, which makes the shocks less effective, and allows the alignment to change. We tried runner ours a bit tighter, with no intermediate nut, and it made it super hard to turn.
Sure a camber plate would be nice to have, but space is tight up top, and the crash bolts get you close.
Old 06-09-2011, 12:51 PM   #9
Jason@SportsCar
Just talked with them... One set is being air freighted in next week so we can test fit them. It appears as though these were made for the JDM, and they are not 100% sure its a go for our cars, although I can't see what the hang up would be. They have lots of options for the bushing that fits inside the bearing, so fitting other brands of shocks should not be an issue.
I will let you know how it turns out.
Old 06-09-2011, 01:28 PM   #10
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
-Type 07 FFL-
My odometer 03/11
Old 06-09-2011, 02:51 PM   #11
This is great Jason, thanks for pursuing it, we all benefit.
Old 06-16-2011, 06:30 PM   #12
Jason@SportsCar
The first set to hit the states are now on my desk... Must resist leaving work and go install these.
When I went to pick them up I took one of my struts with me. Not only does the bearing accept my AST strut, the thread pitch on the Cusco nut is even the same.
I can't say for sure, but I believe there is a good chance these would fit any strut that uses a 12mm pin top mount.
I am going to try and get one in the car tonight.
When you compare this piece to the stock rubber mount it is incredible. The stock upper strut mount is likely the worst bushing on the car. By design it allows the top of the strut to move in all directions, so the suspension does not bind. This movement results in camber change, and creates a dead spot in the shock dampening by allowing it to move up and down as you bounce between loading the busing on the underside of the fender, and catching the washer on top.
This Cusco mount should take all of the play out, while maintaining free movement. I expect this should make for much more precise turn in, and better control of the springs.
I can understand why a lot of manufacturers did not jump on building this part. You have a very odd space to fill, and no camber plate to market. But I am super glad Cusco stepped up to the plate, this should be a massive improvement over the stock parts.
Old 06-16-2011, 07:33 PM   #13
Jason@SportsCar
It gets better... The Cusco Centerlock also fits the OE Yaris shock.
Old 06-16-2011, 07:45 PM   #14
It's a hella lot of coin though.
Old 06-16-2011, 07:50 PM   #15
Jason@SportsCar
It is... But people spend more on dumber stuff. It's also MSRP, a Cusco dealer may sell them for less than that.
Old 06-16-2011, 09:40 PM   #16
YarisSedan
Drives: 08 Yaris Sedan
I need to get me a pair of these now that my factory strut mounts are blown. Its annoying having creaking every time i turn.
Old 06-16-2011, 09:53 PM   #17
auxmike
auxmike's Avatar
That's $371 US dollars, folks.
Bear in mind it will increase interior cabin noise too.
All tolled, I would love a pair!
Old 06-17-2011, 01:26 AM   #18
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
I want!!!
Adjustment to the upper shock mounting point? Goose Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-07-2010 03:41 PM
need measurements of 2009 3dr upper grille blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 2 11-30-2009 10:37 AM
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 02:37 AM
In need of upper and lower grilles and upper grille cover bam2626 Items for Sale by private party 2 06-25-2009 10:34 PM
DIY: Urethane Engine mounts turboyaris DIY / Maintenance / Service 1 05-21-2007 01:08 PM
