#1 |
![]() Drives: 09 Yaris Hatchback Join Date: May 2011
Why dosent my yaris chirp at least second gear
Does the engine not have enough power to chirp at least second gear. Every 5spd car that I have owned in the past was able to at least chirp second gear and sometimes thrid gear. In a way is kinda cool that it dosent but I am not used to it. Its this something that happens only to me or is someone else having the same problem?
![]() ![]() Drives: 09 yaris hb Join Date: Jul 2010
try getting squeekier tires or go try on a concrete road or aim for the white lines haha
if u have a 1.3L u have to find the right revs to change gears to get a noise. if not.. maybe your clutch is on its way out ?? eh? |
#3 |
I doubt that my clutch is on its way out, I just bought my 09 yaris 5spd with 7080 miles on it for $10,885. I got a hell of a deal power everything as well
#4 |
try powershifting?
#5 |
Mr. Clean
Most of the reason is low power and high gearing, but I've always suspected there is some sort of restrictor somewhere in the clutch line or master cylinder. (I know some S2000's had this.) It makes the clutch engagement a little less harsh and makes life a little easier for the transmission. It would explain the slightly odd feel to the Yaris clutch. In any case, since I'm not trying to bang gears, spin tires, and break my transmission, it doesn't really bother me. I have other vehicles for that.
#6 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
You're lucky you could even find a manual yaris with power options. The only 5spd sedans I could find were all barebones crap. I ended up getting an auto because I wanted all the other options.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
power shifting is probably the only way u can.. gotta be quick though, and dont tear up your transmission. i havent had a problem chirping 2nd, but i can see how it would be difficult with this low hp egg
#8 |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
stock 15's or the summer 18's i have no problem getting her to chirp....
#9 |
Where in NoVa are you?
#10 |
Fairfax VA
#11 |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Ugh, I hope not. The IS300 has it so Toyota has a history of putting them in. AND IT SUCKS. Now I will have to go check...
#12 |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
Buy the cheapest chinese tires. They will have no grip in any condition.
#13 |
^ Best answer, LOL.
#14 |
JOE GIRTH
#15 |
![]() ![]() Drives: 2005 Echo Rs Join Date: Sep 2010
#16 |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Yes you can... http://www.youtube.com/watch?v=lxSdW_foc50
#17 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
i can chirp 2nd no problem
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#18 |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
Yeah, a good power shift and I can chirp 2nd with my nitto 205/55/15's, but on stock rubber, just shifting close to red line about did it everytime
| Persuade me to buy a Yaris! | TONIZZLE | General Yaris / Vitz Discussion | 48 | 09-09-2011 11:31 AM |
| Which Redline gear oil is the best for our Yaris? | stevencyt | DIY / Maintenance / Service | 0 | 03-13-2007 11:11 PM |
