Old 06-16-2011, 08:46 PM   #1
auxmike
auxmike's Avatar
Caliper guide pins corroded with rust PICS
Hi all,
Just wanted to share these pics of what the caliper guide pins looked like after 40k miles and 3 years of service. I bought new sets of the pins and 2 new bushings too. Looking pretty bad for something off an '08
I've added the part numbers for your shopping pleasure. I think the bolts are like $6 or so each. There was almost a 2 week wait for these guide pins. Don't know if their running low on 'em or if the Tsunami had something to do with it? Who knows.
Brake jobs aren't always just slapping in a new set of pads, you never know what will come up as you take things apart. If the rust gets bad enough on those pins, the calipers WILL seize!
Old 06-16-2011, 10:19 PM   #2
Who last did your brakes? They may have wiped the pins clean and not re-coated them with brake grease before installation.
Old 06-16-2011, 11:32 PM   #3
auxmike
auxmike's Avatar
The last person to do the brakes was the guy at the....factory in Japan! This was the first time the factory installed parts were disturbed. Not very impressive, eh?
Old 06-16-2011, 11:41 PM   #4
Wow those still look like brand new compared to mine. Mine are pitting they're so bad I have to wire wheel them every 4-6 months now. If I every get myself a metal lathe I'll be making my own pins outa stainless and never worry about them again.
Old 06-16-2011, 11:54 PM   #5
auxmike
auxmike's Avatar
I used this upon reassembling the parts lubing the guide pins with it.
I recommend springing for new pin sets vs. sanding the old ones.
Old 06-17-2011, 06:23 AM   #6
It looks like they should probably be on the list of things to check routinely. Maybe check and re-lube them when switching from summer to winter wheels.
Old 06-17-2011, 07:03 AM   #7
Kongo-Otto
Drives: '09 Yaris & '10 Auris
You should check if these pins have to be greased or not.
Here in Europe we have a different brake system so i can not talk for you over there. Our ATE brake system has guide pins too but they are not greased. They are not supposed to be greased.
Old 06-17-2011, 10:03 AM   #8
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Auxmike,
I remove, clean and lube those pins with the exact lube you posted a pic of (it's what I use on the police cruisers at work) every 5k when I rotate the tires.
That lube is great and will help a lot but IMO the only way to guarantee those pins stay free is by removing them and re-lubing semi annually.
This is not just a Toyota phenomenon, my wire's Nissan caliper pins seized in a year with 30k on them! Environment appears to be the major factor.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-17-2011, 10:24 AM   #9
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
I oiled these studs graphite grease.
Stainless steel is not worth doing it is soft.
MickZEL is offline   Reply With Quote
Old 06-17-2011, 10:51 AM   #10
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Wonder if polishing these would help keep the corrosion down to a minimum...at least it would make them super slippery. A few minutes on my wheel and they'd be mirror finished.
-Type 07 FFL-
My odometer 03/11
Old 06-17-2011, 12:54 PM   #11
bronsin
bronsin's Avatar
Not a problem.
Old 07-10-2015, 01:41 PM   #12
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
can anyone confirm if theres supppose to have a small play on this guide pins... i just did my brakes and i had to sand and grind the lower guide pins with rubber on both side which was corroded..cleaned and lubricated but no play..top one goes back up abit when pressed but not the guide pins with the rubber although it now slides in and out... not i can spin the rotors with one hand but has a slight drag on the pads..is this normal... thanks
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 07-11-2015, 12:27 AM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
You are kidding right...that is the stupid excuse for lack of maintenance on ur part... 08 with low km hmmm car sits rust builds up and honestly I have seen cars with under a yr old with worse it all depends on ur location.
Sent from my ASUS_Z00AD using Tapatalk
Old 07-11-2015, 06:49 AM   #14
bronsin
bronsin's Avatar
Hmm interesting. Lubing the pins isn't something I do on a regular basis. Wifes Camry has 123K on it. Pins not lubed. No problems. 79 MB 240D (gone now) 153k pins never lubed although the pistons in the caliper did seize when the car was like 20 years old. One caliper on the right that is.
Its always been my belief its the pistons that seize in the caliper bores. Then the caliper can lock onto the disc, ruining it and wearing the pads down to bare metal in short order. Not something you want but nothing really you can do about it except check the brakes maybe twice a year when the car gets older.
But this pin seizing thing. The holes for the pin seem too large for seizing to happen. At least not like when happens when a caliper seizes.
Or am I wrong about this and should I be greasing the pins?
Old 07-11-2015, 08:35 AM   #15
nortonfb
Drives: 2007
I was taught to lube them. If nothing else it slows down the rust issue.
On older cars it was sometimes a problem getting them out.
I use Sly-gel it stays and doesn't dry out. On the pins once out, if any corrosion I wire brush them and coat them then back in.
nortonfb is offline   Reply With Quote
Old 07-11-2015, 08:54 AM   #16
ex-x-fire
Yeah, I've seen the pins seize up, a lot of times the pads get frozen in the caliper brackets. Sand blasting them helps, you need to coat the bare metal too.
Caliper Pics at3GG Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-10-2009 08:03 PM
