Old 06-22-2011, 08:32 AM   #1
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
2010 Yaris LB - Want to add OEM door lock actuators
Does anyone know the part numbers/compatibility of the power door lock actuators?
I have a non-power 2010 3-door LB and I have already added the aftermarket conversion as a quick fix but I was wondering if anyone knew the part numbers for the door lock actuators.
I only need the right and left.
bad_bwoy007 is offline   Reply With Quote
Old 06-22-2011, 10:22 AM   #2
http://www.yarisworld.com/forums/sho...light=actuator
They are compatible from 06 to present.
Old 06-22-2011, 01:19 PM   #3
bad_bwoy007
Thanks CTScott,
For anyone searching here are the part numbers:
Lock Assembly, Front Door W/Motor, RH: 69030-52470
Lock Assembly, Front Door W/Motor, LH: 69040-47060
5 door:
Lock Assembly, Rear Door W/Motor, RH: 69050-52190
Lock Assembly, Rear Door W/Motor, LH: 69060-52200
Actuator Assembly, Back Door Lock: 69150-52070
Mounting Bolts: 91511-B0614 (2 required)
Old 07-28-2011, 11:28 AM   #4
LukeSwim
Drives: Toyota
Thank you, this is good news for other visitors
md toyota service
LukeSwim is offline   Reply With Quote
New Yaris 5 DR HB arriving April 5, 2010 mkorejwo New YARIS Purchase Forum 6 04-06-2010 11:39 PM
2010 Yaris purchase ronie New YARIS Purchase Forum 18 09-17-2009 04:52 AM
