Old 06-23-2011, 06:46 PM   #1
jerome
Toyota
Drives: '11 5dr/5spd yaris
So, hypothetically speaking... what does it take to run a 16x8 wheel?
+20 offset.
Are there different degrees of rolling fenders or is there only one way to do it that ends up with the same result?
Rolling fenders + how much camber would it take to make these work? (205/45/16)
jerome is offline   Reply With Quote
Old 06-23-2011, 06:54 PM   #2
which wheel
which tire
and how much is the car lowered
Old 06-23-2011, 06:57 PM   #3
jerome
Toyota
which wheel
which tire
I'm looking at the Grid Offroads (16x8, 4x100, +20)
Not sure which tire... but thought running 205/45/16 size?
And let's say Tein Basics...
Thoughts?
Old 06-23-2011, 07:04 PM   #4
Check this thread:
http://www.yarisworld.com/forums/showthread.php?t=35090
Those are 16x8 +0mm in the back only. This required a major fender pull and the camber you see there.
So, with a +20 instead, you'd still need a pull and some camber but not that extreme. It should help you visualize it though.
Old 06-23-2011, 07:07 PM   #5
jerome
Toyota
Check this thread:
Thanks. I remember going through this thread. (Been doing a lot of research)
What does a fender pull involve? Is it very labor intensive? Front and back pull needed then?
I guess what I'm concerned about most is damage to the fenders...
Old 06-23-2011, 09:01 PM   #6
Pulling the fenders is considered "damage" to a lot of people. The plastic bumpers should follow the fenders out as they are pulled. Pulling takes some time and skill, and the proper tools.
I put flares on my car instead, then welded and trimmed the fenders -- that is a PERMANENT decision. :)
I'm running 15x9 front and rear with 235's.
Old 06-23-2011, 09:43 PM   #7
coheed
Drives: 08 BB LB
This is how you roll fenders lol.
http://www.youtube.com/watch?v=DDTK9IjKIYU
Most people dont want to do that to their car.
Old 06-23-2011, 09:54 PM   #8
Mister Z
Drives: 08 Yaris HB
I'm currently running 15x8 +25 all around and all i needed to do is roll the front fenders. But I am on coilovers tho. The tires I'm running is 185/60/15, the stock tire size i believe. But I will be changing my tires to 195/50 to have a smaller sidewall and larger width.
Mister Z is offline   Reply With Quote
Old 06-24-2011, 09:17 AM   #9
jerome
Toyota
[IMG]yaris2.jpg[/IMG]
damn. crazy.
i wouldn't even know where to go to get my fenders pulled. i guess even more worried about the end result.
boo. because those 16x8s would look pretty good, me thinks. if i could somehow manage to find a guy to properly roll and pull my fenders, how much camber do you think i would need on the front and rears? just trying to gather what i need to accomplish all of this..
Old 06-24-2011, 03:36 PM   #10
SLOWSK8
SLOWSK8's Avatar
Drives: Blitzd Yaris
I found this yaris on google. I think this is the same set up you looking at..I love the look.
SLOWSK8 is offline   Reply With Quote
Old 06-26-2011, 03:48 AM   #11
jerome
Toyota
Originally Posted by SLOWSK8 View Post
Attachment 42529
wow, nice find. i wonder what that's lowered on? doesn't look low enough?
i'm worried if i go this route the tein basics won't be low enough...
Old 06-29-2011, 12:19 AM   #12
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I have 15x8 25 offset on the rear and honestly the only time i rub is on big dips or really uneven surfaces and that is on the side of the tire
Tire size is 205/50/15 onthe rear and dropped on DF210s
No tire damage with only a minor tap up on the inner lip of the wheel well,not even fully rolled....easy to do.
You should be fine with that offset andsize tire/wheel as long as you dont mind some minor rubs now and then.
In a few months I am gonna put in airbags and some rear camber and hub spacer for about 10mm more.
Fronts are 7 wide 35 offset 195/50s on it and little to no rubbing ever,old set up with 17s I rubbed drivers side mostly,rubs on plastic fender liner only.
I would think maybe 2-3 degrees camber in the rear and 1.5 in the front will be my final settings and it should also work with your offsets and size about the same...hope that helps some.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 02:37 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
