Old 06-24-2011, 03:28 PM   #1
rmcmilli
Drives: 2008 Toyota Yaris
Question Moving aux port
Hey everybody, I have a stock toyota stereo with the aux port on the passenger side behind the center of the dash. Is there any way to move it to one of the unused spots in front of the parking brake? I can't seem to get it disassembled in a way to move it.
rmcmilli is offline   Reply With Quote
Old 06-24-2011, 03:32 PM   #2
The Aux jack has two plastic tabs on the back side (top and bottom) that hold it in. To remove it you have to squeeze them and then slide it out of the front of the hole.
Old 06-24-2011, 03:43 PM   #3
rmcmilli
I have the sedan if that makes any difference
Old 06-24-2011, 03:45 PM   #4
It doesn't. The Jack is the same, but is just installed in a different place.
Old 06-24-2011, 03:48 PM   #5
rmcmilli
Alright thanks a lot. I'll try it
Old 06-24-2011, 04:12 PM   #6
rmcmilli
Any idea on the wiring? The wire attached seems a bit short. I saw that another member Had done his but there was no info on it
Old 06-24-2011, 04:23 PM   #7
The wiring is bloused into the dash wiring harness. If you follow it back, you may be able to remove some tape a free up enough to move it. Otherwise, there are four wires and a shield that you would need to lengthen.
Aux Port - Canadian 2006 Yaris spryguy007 In Car Entertainment + Electronics (audio / video / alarm) 42 04-17-2022 12:33 PM
Aux port = Ipod Fewgoodmen17 Middle East 5 05-25-2011 01:40 AM
How do I can install (AUX) Port ??....>> boadel In Car Entertainment + Electronics (audio / video / alarm) 8 02-15-2010 05:40 AM
Switched amp for AUX port with Aftermarket stereo? CtrlAltDefeat In Car Entertainment + Electronics (audio / video / alarm) 6 05-28-2009 02:34 AM
question bout aux port SurfBabe900 General Yaris / Vitz Discussion 1 05-28-2007 02:18 PM
