Old 06-27-2011, 11:04 PM   #1
springer1978
Drives: yaris hatch 08
foglight help
Ive searched , maybe not well enough but for the last 2 hrs. Im installing a mi foglamp kit on a 08 3dr lb. my issue is my lamps do not come on and the switch is constanly lit up. Im using the swutch from the kit and pin 3 on the stalk connector is conected to nothing when i unplug it and look inside the other end? If someone could direct me to instructions on using the supplied switch i would appreciate it
springer1978 is offline   Reply With Quote
Old 06-27-2011, 11:14 PM   #2
Pin 3 on the stalk is not used unless you have a stalk with the fog switch on it. That is why there is not a pin there. If everything else is wired correctly and the foglight relay is plugged in to the under dash fuse panel, then jumping pin 3 to pin 4 on the stalk connector will make the lights come on (provided that the headlight switch is in the on position as well).
Old 06-27-2011, 11:26 PM   #3
springer1978
wich one is pin 4 in coralation to 3. and the relay is in.
Old 06-27-2011, 11:30 PM   #4
Old 06-28-2011, 12:20 PM   #5
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
Scott,
I bought one of these off of ebay
and will install it this weekend have no idea how to wire this, any instructions would be greatly appreciated.
Thanks in Advance and we shall call you Yaris Guru
PROX4x4 is offline   Reply With Quote
HELP!!, HOW TO INSTALL FOGLIGHT YARIS SEDAN?? shangapol DIY / Maintenance / Service 12 11-28-2012 12:53 PM
Stock/aftermarket Foglight Question? Yaris4L1fe Cosmetic Modifications (Exterior/Interior) 19 06-23-2011 06:47 AM
FS: Foglight Switch including Relay AzNguy Items for Sale by private party 4 10-19-2009 11:04 PM
WTB: 06 Hatch Foglight Covers (non foglight) hasher22 Willing to Buy by private party 2 06-24-2009 12:35 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
