#1 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
so today i was driving normally like every other day and these 2 dash lights came on for no apparent reason. (check engine and the "slip" *not the traction) i did nothing went about my business they stayed on after 2 stops and starts, then i drove to brooklyn was there for a few hours got back in to leave and they never came back on. any opinions or info ? pretty weird only thing i could think of that might have caused it, i was running the ac before they came on for longer than i usually do (was on the phone with mi in the car while it was running getting something sorted out and ordering the ecometer) but i dont see why that would be a cause
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
Its just a check engine light. Id get that checked out first.
Sometimes when the check engine light comes on, depending on the code, the VSC or "slip" light will come on. Its a engine fail safe thing. |
#3 |
yeah my buddy said they would have stayed on if the problem was eminent and if not then its intermittent every few cycles itll turn off but store the data so im gonna hook it up to his scan tool he can check the codes ill post here when i do
#4 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
I'd try to get some soft codes pulled via an OBDII reader or SGII. I'm thinking you have one or two if your CEL came on, but is now off.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Check engine light code: P0724 | OttenVT03 | DIY / Maintenance / Service | 4 | 10-16-2012 02:12 PM |
| question about the cold engine light | Yarus Maximus | DIY / Maintenance / Service | 26 | 01-22-2011 07:55 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| weird sound when engine at around 2000 rpms | soup1207 | DIY / Maintenance / Service | 38 | 06-05-2009 10:01 AM |
