Old 06-30-2011, 03:31 PM   #1
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
MI springs and swaybar. Which swaybar?
I think I am finally over my whiplash enough to finally get lowering springs. I have held off do to the firmer spring rate.
Which swaybar do you guys recommend for a sedan? the 19mm or 23mm? Has anybody here actually tried both?
Old 06-30-2011, 03:36 PM   #2
chewychewbacca
Drives: 08 Yaris S 3Dr
I would get the 23. I have the 19 but I'm finding that I would like a bit more stiffness. I remember Garm posted that the 23 was a 15% or so increase in anti sway however don't quote me on anything ;)
chewychewbacca is offline   Reply With Quote
Old 06-30-2011, 03:43 PM   #3
There is no downside to the 23mm sway bar, other than price; the sway bar only affects the car in turns.
Old 06-30-2011, 03:47 PM   #4
chewychewbacca
And I'm very happy with the MI springs. They provide a nice drop and are nice and stiff. Go place your order :)
Old 06-30-2011, 03:55 PM   #5
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
I've reasearched this topic so many times and learned quite a bit about swaybars. If you do the same I guarantee you'll make the right choice, guaranteed. (and yes, poster had tried both)
Start here:
Ultra Racing 23mm Rear Stabilizer Bar
My Ultra Racing rear sway bar install
-toy
Old 06-30-2011, 04:49 PM   #6
Flipper_1938
Start here:
-toy
After reading that, I'm not so sure. I have no plans on autocrossing this car, I just want a lower profile with "sportier" handling.
The ability to induce oversteer at will does not give me a warm and fuzzy feeling. I will probably end up getting the 19 mm.
Old 06-30-2011, 04:55 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have the 19 and for street driving I find it to be a perfectly fine choice.
Old 06-30-2011, 06:41 PM   #8
Flipper_1938
How long have you had it installed?
Old 06-30-2011, 09:39 PM   #9
Here's my suspension set up.
TRD Sportivo Shocks
Tein S.Tech springs
Tanabe front strut bar
TRD rear sway bar (I think TRD is 19mm, right?)
GT-Spec rear sway link brace
2-pt Megan front lower tie bar
2-pt Megan middle lower tie bar
the useless 2-pt Megan rear lower tie bar
Right now, with my generic tires and heavier rims, I have a slight understeer (felt better without the lower tie bars as it was more neutral then). If you would prefer to stay with slight understeer, go with 19mm. I wish I had the 23 mm tho.
Old 06-30-2011, 09:43 PM   #10
TRD is 19mm, correct.
And yes, I've had both on my car too, both on the street and at the track.
Old 06-30-2011, 11:16 PM   #11
sickpuppy1
I have the 19 and want the 23, wonder how we could work out a trade.......had it about 6-8 months....
Old 06-30-2011, 11:17 PM   #12
sickpuppy1
shipping would suck though and its included with garms stuff isnt it?
Old 07-01-2011, 12:41 AM   #13
You'd have to sell it (On here is a good place to try) and then buy a new one.
Old 07-01-2011, 03:54 AM   #14
matthewai
matthewai's Avatar
Drives: it is kinda stock
i have 19 i dont think theres a need to go with the 23 at least for just reg driving around. its great to just have the ability to take turns at 45-50 even with the 19 ive always felt confidant that the car will make it so far
Old 07-01-2011, 03:44 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
Adding a 19mm bar will make a world of improvement for both handling and stabiltiy.
That said, I'm now considering the step up to a 23mm bar as understeer is still prevalent. And when the weight of the Blitz S/C is added up front the power-on understeer can only increase. Time will tell.
Old 07-01-2011, 04:14 PM   #16
Flipper_1938
With your current set-up, in the rain or snow, do you get understeer of oversteer?
Potential crappy handling in bad weather is the only thing making me consider the 19mm one.
Old 07-01-2011, 04:20 PM   #17
fnkngrv
fnkngrv's Avatar
About a year now...you really had to make me think about it...I can't believe that I have had it on as long as I have. I really need to catalog my mods better. You have inspired me to built it all into my OneNote...thanks!
Old 07-01-2011, 04:29 PM   #18
Flipper_1938
How does your car handle of slick roads? ...better of worse than stock?
Swaybar vs. lowering springs eht13 General Yaris / Vitz Discussion 52 10-04-2010 07:59 PM
Front swaybar deconnection....anyone tried it dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2007 10:20 PM
