Old 06-30-2011, 10:02 PM   #1
kurisu
Drives: 2009 Yaris
Synthetic Oil interval?
Hi guys,
I decided to go synthetic oil this time. I picked up valvoline sythetic blend 5w-20 with mobil 1 filter at my local autozone for $21.99. I've been doing 5k oil change. I'm not sure if the interval for synthetic oil is more than 5k.
kurisu is offline   Reply With Quote
Old 06-30-2011, 10:35 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Valvoline Syn blend I'd go 5k/6 months. Unless you have a nearly 100% highway driving cycle I'd go no further with that oil without a used oil analysis that included TBN. If your still under warranty I'd stick to 5k regardless.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 07-01-2011, 07:45 AM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
when ever i used synthetic in cars, i automatically go to 5k...but it figures, thats what toyota specifies for the regular oil change interval
i run mobil-1 0-20w Eco oil
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-01-2011, 07:58 AM   #4
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
after my oil analysis i wouldn't use 5w20. Don't know if its blow by from rings or what but my oil had a lot of gas in it causing the oil to thin out some
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 07-01-2011, 10:30 AM   #5
bankrobber
Drives: 2007 Yaris Hatchback
I would go at least 7,500 with a good wix filter. I went over last oil change and went to 11,000 miles and oil still at full mark looked ok too. Running Mobil1
Old 07-01-2011, 10:40 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
are you running NA or FI?
Old 07-01-2011, 11:18 AM   #7
bankrobber
not sure what that is
Old 07-01-2011, 11:58 AM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I go 3k, but I get the 19.99 Mobil 1 gallon jug from Walmart and a cheapo fram filter so it's the same price as a regular dino oil change.
-Type 07 FFL-
My odometer 03/11
Old 07-01-2011, 04:31 PM   #9
fnkngrv
fnkngrv's Avatar
NA = Naturally Aspired, in this case stock
FI = Forced Induction, boosted with either a supercharger or turbo
Old 07-01-2011, 05:05 PM   #10
bankrobber
lol, mine is stock...NA
Old 07-01-2011, 05:37 PM   #11
R2D2
Crazy Oil Sniffer
R2D2's Avatar
I'm afraid that's pretty typical, regardless of oil weight used. It's a big part of the reason I'm not a fan of blindly extending oil change intervals regardless of the oil type, or weight used.
Although it seems odd thinner oil isn't necessarily "bad" where fuel is present and other factors about a chosen oil can be much more important than it's rated viscosity.
My last report was about 1.6% fuel dilution.
R2
-The Fitful One
Old 07-02-2011, 08:59 AM   #12
swidd
Drives: Yaris HB
Does it matter if there's some fuel circulating in the oil?
Old 07-02-2011, 11:34 AM   #13
Happy Little Pony
Drives: 2007 Yaris HB
Even in a modern, fuel injected car there's always going to be some small amount of unburned fuel that makes it into the oil. Most all of this evaporates on a long drive when the engine gets up to full operating temperature for an extended period. But if a person rarely (or never) drives their car long enough for the oil to get really hot, then this fuel (as well as other contaminants) never gets burned off. The oil just gets more and more diluted by contaminants.
This explains how one car can go 10,000 miles and its oil is still good, but another can go 2,000 in the same time and its oil is bad.
Happy Little Pony is offline   Reply With Quote
Old 07-02-2011, 01:07 PM   #14
Hershey
Still need to stay with the 5,000 mile or 6 month interval to keep your warranty . Doesn't matter if it's conventional , a blend or full synthetic . Also keep your receipts of the oil and filter for records in case there's an issue .
Old 07-04-2011, 03:37 PM   #15
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Well put.
If the fuel doesn't get evaporated out it can thin oil out, affect lubrication and create deposits.
-The Fitful One
Old 07-04-2011, 06:18 PM   #16
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Whats the logic in changing the oil at half the mileage the manufacturer recommends then cheaping out on the filter?
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
