Old 07-02-2011, 04:01 PM   #1
Darwin84020
Drives: 2007 Yaris, Hatchback
Question Soon to be upgraded wheels, need advice.
Hello,
I will soon be upgrading my wheels and tires on my car from the standard OEM, 185, 15” inch wheels to some 17”s , but I have a question that I have seen similar answers too, but not exactly.
Original tires/wheels
185/ - 15”inch steels Yokohama OEM.
Upgrades tire/wheels
205/45/17 - 17” inch - Enkie EDR9 (17x7). (38 offset - which is best from what i have read).
Wrapped with rubber- Yokohama AVID ENvigor (H&V) shown on tirerack as a 205/45R17.
My main concern is rubbing/ scratching, I would not like to hear this very often – if at all, and wanted to know from more knowledgeable people here, if this will happen, and if so how much will it rub.
Edit
From what i can find on tirerack, the 205/45R17 and the current 185/65R15 have the same/ similar diameter, 24.3 vs the current 24.4, so i guess this answers my own question, and should be fine, any ones else concur. Only real difference is the Rim Width and the Tread Width.
Darwin
Darwin84020 is offline   Reply With Quote
Old 07-02-2011, 06:44 PM   #2
Lil Abner
Drives: 2009 3dr LB Manual
Is you car currently lowered? Or will it ever be?
Old 07-02-2011, 11:57 PM   #3
ChitownY@Ris
ChitownY@Ris's Avatar
Drives: '07 Yaris Sedan
Well I know the 215/45/17 Yokohamas I just put on my stock 07 sedan kiss the front wheel well on big road dips i.e bridges and train tracks. Other than that they ride great and the ride height is slightly higher at 45. But still, the rub can get especially aggravating day in day out. I'm sure the plastic wheel well can only take so much before it gets annihilated, and from what I gather, that plastic liner goes for like $400 to replace. I'm gonna switch to either 215/40/17, but if the shop says there is ANY hint of a rub risk with those, I'll go further down to the sure thing of 205/40/17.
ChitownY@Ris is offline   Reply With Quote
Old 07-03-2011, 01:23 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If your car isn't lowered then the setup you have (17x7 +38 offset with 205/45/17) will be fine.
Old 07-03-2011, 02:26 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
Your OEM rubber should be 185/60-15, not 185/65-15. 185/60-15 has a diameter of 23.7" so you may well be advised to go to 205/40R17 for something closer or slightly smaller to further lessen the chance of rubbing.
Good Luck and Enjoy!
Old 07-03-2011, 03:32 PM   #6
ciscobear
Drives: Toyota Belta
yup I will be going with a 40 series when I am ready as well. 45 is too fat imo.
ciscobear is offline   Reply With Quote
wheels and tire combo advice. bwd1973 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-26-2011 12:13 PM
Tire advice for 17" wheels coolj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-12-2011 01:06 PM
Ordered some wheels, need advice on tires 47_MasoN_47 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-21-2010 04:56 PM
Could someone give me some advice on these set of wheels fujiwaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-25-2009 07:33 PM
