#1 |
pardon the newbish nature of the question.
how will tire and wheel size affect mpg? i.e. larger rims v. smaller rims, fat tires v. low-profile tires and how drastically will lowering a car affect mpg? im looking to pick up a yaris soon (my '94 camry finally died ) and would like to strike some balance between the car's natural fuel efficiency and absolute rolling teardrop sexiness when it's on a nice set of wheels.
![]() ![]() Drives: 2010 5 Door Join Date: Jan 2011
When i change wheels, which is a 5lb difference per wheel, my gas milage changes 3 to 4 mpg.
#3 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Larger, wider= less MPG.
Larger, lighter (more expensive) = maybe neutral change. ....emphasize maybe. Basically use the stock wheels for a gauge. If you put anything grippier or wider, or heavier the difference will eat up the mpg. Lowering actually helps out with the mileage as more air is forced over the car. Drive the new car for a month to see your mpg before the change.
#4 |
![]() ![]() ![]() Drives: 09 5dr Yaris Join Date: Mar 2009
More narrow tires will increase MPG since there is less contact patch.
Wider wheels will decrease MPG. Heaver wheels will decrease MPG. Lighter wheels will increase MPG. Note that if you change the rolling diameter of the wheel the speedo will be slightly off and skew the MPG a little since your speedo will read off as well. Angela |
| Chevy Cruze ECO earns an astounding 42 MPG EPA Highway rating! | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 02-05-2011 11:29 AM |
| 17" VS 16" Weight and MPG | longlivekel | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 06-25-2010 09:59 AM |
| FE Turnaround: Disappointment to Satisfaction, 2010 Yaris. Almost +50 MPH. Thank You! | STC | Fuel Economy Forum | 12 | 04-17-2010 12:21 AM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 05:23 PM |
| Wheels & Tires For MPG | S1L3N7 D3A7H | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 01-30-2009 11:45 AM |
