Old 07-07-2011, 02:51 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well water pump its almost out of commission..
thought it was the alternator making the grinding noise..i now found i little pink stuff inside the water pump pulley so were 100% sure bearing is gone and thats whats making the noise....still under warranty..but 80k kms on this pulley? really??
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 07-07-2011, 04:39 PM   #2
BLH
Drives: 2007 Yaris Sedan
Yes there are many reports of water pump failures.
I am a very low mileage driver.
My 2007's water pump failed two months ago at about 15,000 mi.
Nice pink stuff inside the pulley and a line of pink spray from the front to back on the inside hood.
Still in the 5 year 60,000 mi warranty.
Now if I could ever get the ECU to show a ready condition on my Scanguage. I would be happy as the battery was disconnected when the pump was changed. Thank goodness I had the CT. emissions done before the pump was changed.
Old 07-07-2011, 04:55 PM   #3
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
you have no luck when it comes to these pumps huh???
ROCKLANDTOYOTA is offline   Reply With Quote
Old 07-08-2011, 07:17 PM   #4
thepartsmancometh
Drives: '08 LB, '07 WRX
We don't see as many yaris pumps as other models, but overall a lot of toyota W.P.s go bad. There is speculation amongst the techs that it has something to do with the formulation of the pink coolant (red coolant cars never had this issue). A rep from Aisin said they had changed the impeller material during production as well (no confirmation on this one)
thepartsmancometh is offline   Reply With Quote
Old 07-08-2011, 08:49 PM   #5
auxmike
auxmike's Avatar
My second OEM pump started leaking after 1500mi. I think I tried to tighten the alt to where the factory had it and hurt the pump. I've since loosend it and after a few months time it seems to have stopped..
Old 07-08-2011, 10:03 PM   #6
Cosworth
Drives: S sedan
We just had our water pump replaced under warranty. '07 model year purchased in '06 with just a few thousand miles under 60,000 mi.
Swapped out the serpentine belt while we were at it.
Cosworth is offline   Reply With Quote
Has anyone had their Water Pump replaced? Carrot Top DIY / Maintenance / Service 48 03-20-2017 01:32 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
