Old 07-09-2011, 09:07 PM   #1
romram
Drives: yaris hatchback
GPS placement
where is the best place to install/place a garmin GPS on yaris?
i want to keep the wiring (from 12v outlet) out of sight?
romram is offline   Reply With Quote
Old 07-10-2011, 12:15 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
that is a matter for great debate it could seem. Do you have any reason why you wouldn't want to hard wire the power cord rather than being stuck using the 12v outlet?
Old 07-10-2011, 05:12 AM   #3
romram
yap. i rather used the orig wire from garmin, since it also works as an antenna for traffic update..
Any picture around? how you place your GPS on the dash?
Old 07-10-2011, 07:55 AM   #4
Revsson
I know you are new, so thought I would post some links.
Others will tell you to use the Search button up top...which you can do
http://www.yarisworld.com/forums/sho...t=mounting+GPS
http://www.yarisworld.com/forums/sho...79&postcount=4
You can also search for 12v outlet and probably find the links where others
have mounted a hidden 12v power outlet to plug in their GPS or mp3 players
for a cleaner and stealth look. Perhaps that would meet your requirement for
using the stock power cord and be hidden?
Check out the links I posted in a response below:
http://www.yarisworld.com/forums/sho...31&postcount=8
Let us know what you come up with, especially if it is different than these.
Old 07-10-2011, 09:26 AM   #5
romram
thanks a lot!
it's a BIG HELP!
GPS revisited Lorenzo1950 General Yaris / Vitz Discussion 5 11-18-2010 08:43 PM
GPS PERMANENTLY INSTALLED IN YARIS JetfireK General Yaris / Vitz Discussion 0 09-06-2010 04:28 PM
FOR SALE L@@k Garmin nuvi 265WT GPS w/ 4.3" Diag. Screen,Case& Traffic pennyracer Items for Sale by private party 1 07-16-2009 07:53 PM
