#1 |
![]() Drives: 2010 yaris Join Date: Jul 2011
I don't know what happened??
I have a 2010 yaris; today I left the ignition key on and the battery almost drained. There was still enough left that the presets on the radio and the clock was still correct. I used my boat bat. to jump start the car...Now I find that my ipod will not come on in the aux position (it did in the aux position before I let the battery go down). My car has a aux pig-tail in the glove box that plugs in to the ipod. Cds still work, I can plug a music player in to the aux jack by the break lever and it works through the aux. I seems that if the radio is on I can't get the ipod to work...But, when I disconnect the ipod and reconnect it, it will play until I switch back to the radio, then attempt to reconnect to the ipod it will not work, the aux button brings no results; nothing on the display either...What am I doing wrong?
Have you checked the fuses?
#3 |
bring it into the dealer. it should be under warranty.
#4 |
MY best guess is that when the battery drained down to its lowest point it messed up the programing in the radio. I disconnected the battery (after recharging) for 10 minutes; reconnected the battery and all worked as normal. Thanks for your input...73s... tom
| Tom Tom to provide embedded PND for Yaris | mehrit | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 07-05-2009 02:09 PM |
