Old 07-17-2011, 12:03 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Upgrading to TRD springs
I was wondering upgrading to TRD springs do I also need to upgrade the shocks? If so can I buy microimage Tokico shocks instead of the TRD shocks? And if I leave the shocks, will there be any problems?
another side, if I just upgrade the shocks and keep stock spring, will there be any problems and what would that gives to the ride??
Lastly, what's the typical rate for suspension work done for the springs? and/or with shocks?
Thanks
caineroad is offline   Reply With Quote
Old 07-17-2011, 11:30 AM   #2
you can change out just springs, or just struts/shocks, keeping in mind two things.
1. stock shocks will probably not last as long with lower/stiffer springs, as they are only valved for one purpose.
2. Changing the other parts later means double the work.
I would buy H&R springs over TRD; better value and a progressive spring with about the same drop.
** We make springs, but the struts/shocks you mean (I think) are Tokico, just to be clear.
Rates vary, don't know what they would be in your area. Get a flat rate quote if you can from a shop you like.
Old 07-20-2011, 09:32 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Insufficient damping?
Personally I would never take away suspension travel without increasing shock damping rates to avoid bottoming and control rebound.
+ unless it's your labour of love (meaning you're not paying a shop) the cost to go back later to upgrade the dampers might equal the cost of the sporty dampers going in the first time around.
++ the handling will be MUCH improved with sport dampers.
Good Luck and Enjoy!!!
Old 07-20-2011, 10:57 PM   #4
detroiter
detroiter's Avatar
I figure just do it right the first time since your already in there. Just install the shocks/springs at the same time and be done with it. You'll save yourself the hassle
of doing it twice and enjoy the enhanced driveability
Old 01-30-2012, 11:58 PM   #5
yPod09
All black everything.
yPod09's Avatar
Drives: '09 5dr All black.
Garm, thanks for posting something about the H&R's, I was just starting to look at them on MI, but having a tough time finding anything on YW. May go with those instead of Pro-Kits. For a slightly lower drop. Pretty similar quality?
yPod09 is offline   Reply With Quote
Old 01-31-2012, 06:35 AM   #6
You'll be.fine with Ted's on stock shocks. I'm pretty sire eibach makes the Trds so they'll have progressive rates.....toyota dealers in Canada just sell eibach prokits as TRD springs anyways....I know because I had some.
Depending on your mileage, I would just opt for tokico blues versus running stock shocks. If you need help installing the suspension, I'm out of work and could do it here for you....I've done mine a half dozen times and other members like bezzz in the past
Old 01-31-2012, 10:04 AM   #7
33OH
Drives: '08 Yaris
My stock shocks just went out at 102,000 miles and my car has been lowered over 2" its whole life (on Tanabe DF210's, and now just put in Tein S-Tech's). Will be ordering some Tokico blue's soon to swap them out with, but I don't regret using stock shocks while lowered.
Old 01-31-2012, 05:46 PM   #8
matthewai
matthewai's Avatar
Drives: it is kinda stock
i also have stock shocks lowered on mi springs no problems at all (1 year later)
Old 01-31-2012, 07:44 PM   #9
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I have been lowered on stock struts as well for about 2500 miles.
I would recommend installing these yourselves. The price to install is going to be probably close to double the value of the springs.
FS: TRD Springs carguy Items for Sale by private party 5 04-02-2010 02:37 AM
Tanabe NF210 + Tokico vs. TRD springs and shocks fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-19-2009 03:42 PM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
TRD shocks with tein or trd springs? UKblackyari Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-20-2008 12:20 AM
