Old 07-17-2011, 04:57 PM   #1
bronsin
bronsin's Avatar
Car WIll Not Shift Into Gear
My wife called me from her Camry saying the car wont go into Drive. By the time I got there my daughter read the owners manual. She found the little plastic cover and pryed it off. Under that is a button. You push the button and now the car goes into Drive.
I noticed my Yaris has a plastic civer near the auto gearshift too.
Now here is my theory.
There is a "safety" (heavy sarcasm) interlock that makes you press the brake pedal before you can put the car in Drive. Thats whats messed up right? Theres nothing wrong with the transmission right? The manual says "see your dealer as soon as possible" (so they can put a new transmission in it or charge you $2500 to fix it)
My wife can just keep on pressing the button to drive the car?
Note: one does NOT need a safety linerlock to apply the brake pedal before shifting into D or R.
We will see if rational minds get their way or if the car goes to the dealer so we can be fleeced.
Old 07-17-2011, 05:53 PM   #2
That is correct - It is just an electrical interlock.
On your Camry, check the ECU-IG, ECU-ACC, and STOP fuses
Old 07-17-2011, 05:57 PM   #3
bronsin
bronsin's Avatar
Thanks so much!
Old 07-17-2011, 06:52 PM   #4
bronsin
bronsin's Avatar
ECU IG and ACC are good
STOP blown 15 amp
Replaced it and it blew again. Car did not shift into D.
Any enhancement possible?
Old 07-17-2011, 08:18 PM   #5
Interesting - STOP is only supposed to be a 10A fuse. I wonder if the owner before you "upgraded" it to a 15A. With that fuse blown the brake lights won't light.
Does it blow as soon as you put the fuse in, or not until you step on the brakes?
Old 07-17-2011, 08:41 PM   #6
bronsin
bronsin's Avatar
I think the cover over the fuse box identified it was 15 amp. We are the first and only owners. Dont have the car at this moment to check but pretty sure its ID'd as 15 amp....
Started the engine, stepped on the brakes, tried to shift into D.
Dont know at what point it blew.
Will do more tomorrow...
Car is 2005 model year.
If the fuse blows when you turn the ignition on, what does that tell you?
If it stays intect upon switching on the ignition, but blows after the brakes are pressed, whats that tell you?
Car has a trailer wiring harness.
Old 07-17-2011, 08:44 PM   #7
What year Camry is it?
Old 07-17-2011, 08:55 PM   #8
bronsin
bronsin's Avatar
2005
Old 07-17-2011, 09:01 PM   #9
Lil Abner
Drives: 2009 3dr LB Manual
Trailer wiring harness? Can you check those wires to make sure there isn't corrosion, or exposed wires that are shorting out? Perhaps the person who installed it made lousy connections that came loose?
Old 07-17-2011, 09:04 PM   #10
bronsin
bronsin's Avatar
Yeah I want to check that. Whatever is causing the fuse to blow it happened today when she went to Wawa. She was driving around before that and didnt have a problem with the car not shifting into drive.
The harness have been connected to a trailer like once in its life.
Possibly something is shorting out the trailer wiring connector Im thinking.
Have to believe the harness was installed INcorrectly
a) because I did it
b) its been fine for six years.
Old 07-17-2011, 09:07 PM   #11
Actually that's a good call on the trailer harness - I didn't realize it had one. The common failure there is a salt bridge or a wire that has disintegrated to the point that it falls loose and shorts. It happened to me once with my Subaru.
Old 07-17-2011, 09:09 PM   #12
Lil Abner
Well, I personally consider myself very good at wiring and electrical stuff. But sometimes, I make stupid mistakes. Like, not crimping connectors enough. We're only human :-)
I'd say check the wiring, then start checking the bulbs. Pull the sockets out of the lights, and pull one STOP bulb out at a time, and check those. Perhaps a bulb is actually shorted out.
Sadly, blowing lots of fuses to check things gets expensive. It's a long shot, but do you have any 15-amp resettable circuit breakers? Do you have a voltmeter?
Old 07-17-2011, 09:26 PM   #13
bronsin
bronsin's Avatar
CT you were right the brake lights dont work. But
Problem solved.
The wiring harness was shut in the trunk latch a long time ago judging by the dammage. The wires must just have shorted together.
I cut the dammaged section out and taped the wires.
The fuse IS 15 amp as id'd on the cover.
I put a 10 amp in. It didt blow on turning on the ignition. It didnt blow on starting the engine. It didnt blow stepping on the brakes.
Brake lights work and car shifts into D.
I put a 10 amp fuse in there as the spare 15 amp was tried and blew. Fuses look to be Toyota specific. Generic ones wont work? Im thinking.
Thanks all.
Old 07-17-2011, 09:36 PM   #14
The fuses are low profile mini fuses. You can buy Bussmann brand ones at auto part stores. I was looking at the 07 EWD. For the 05 it is 15A, whereas for the 07 it is 10A.
Old 07-17-2011, 09:56 PM   #15
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
CT you're awesome.
Old 07-18-2011, 11:13 AM   #16
bronsin
bronsin's Avatar
You know...thinking about this...disableing the transmission because the brake lights dont work is pretty nuts...
Cant there just be a warning light "Your brake lights are out." ?
Old 07-18-2011, 11:19 AM   #17
Actually it was disabled because the fuse was blown. It wouldn't be disabled if a bulb was dead.
Old 07-18-2011, 11:29 AM   #18
Scott to the rescue!
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 10:52 PM
Arkhangel - Photo-Scavenger Hunt Arkhangel Photo-Video-Media Gallery 0 03-01-2009 02:03 PM
