Old 07-20-2011, 11:53 PM   #1
metalshark
MetalShark
Drives: 2008 Yaris LB
Yaris tachometer programmable
I built this digital tachometer using the Parallax Propeller micro-controller. It is programmed in Spin interpreter language.
link: on YouTube.com
http://www.youtube.com/watch?v=wkKVY..._order&list=UL
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 07-23-2011, 12:29 AM   #2
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
wow
ricepower is offline   Reply With Quote
Old 07-23-2011, 02:01 AM   #3
pretty cool, did I see it jump to 6600+ on acceleration? At 0:32.
The rev limit is 6250, so you might want to take a look into that.
Old 07-23-2011, 02:07 AM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Tag
-Type 07 FFL-
My odometer 03/11
Old 07-23-2011, 11:30 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
it is nice, but as was noted in the vid, it is a tad off on the high side. And maybe it is percentage wise, because 6600 rpms woulda prolly damaged a stock engine.
Colin Chapman disciple
Old 07-27-2011, 11:16 AM   #6
metalshark
MetalShark
Yaris gearing/rev limits
I checked the tire size and gearing specs. Calculator says I'd be at 6,330 RPM at 65 mph in third gear. I'll reprogram my calibration constants today. I also need to add a method to flash the display above 6000 rpm. On the earlier BS2 bar graph tach I used the flashing display but that was in pBasic instead of Spin.
My next goal is to enable and calibrate the speedometer readout. Then when I go to a bigger tire size I can easily re-calibrate it myself against the GPS.
Old 07-27-2011, 01:16 PM   #7
Maybe if there weren't a rev limiter set to 6250.
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
