Old 07-21-2011, 11:53 AM   #1
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
To boost/improve Yaris, or move on....?
So I'd appreciate your input on this subject, and especially those of you who took the turbo plunge.
My goal: a reliable lightweight car for street transportation that will still give cooper S cars a run for their money in street class time attack. I have a MR-S race car, and don't have intentions of making my street car into a very competitive car. I do, however have a goal of making it road course worthy (preventing oil and fuel starvation, coolant overtemps, brake fade.)
I own: 2007 Yaris USA 3-door with no options, good quality springs, struts/shocks, rear swaybar. I have owned some much "nicer" cars in my day, but I'd have to say this is probably the best street car I've owned. It is a blast to drive, but obviously with a couple limitations. 1) power-I don't need a ton of it, but it doesn't even have enough power to maintain throttle through corners on the track. 2)suspension-front strut tower mounting (or lack thereof) and the rear end "is what it is"
I used to own a turbo cooper s (stock with good suspension) that my buddy and I would both drive in different time attack events, and we did ok. The car was lots of fun, surprisingly strong, and a pain to work on. I unfortunately had a incident with a couple deer and no more cooper.
My question is....to meet my goals above, do I pursue another cooper, or make the yaris a better weapon?
Proposed Yaris plan: Zage turbo kit to produce approx 150hp for some reliability. I think most guys tune for more boost/power than that, but I'm not interested in pushing the limits of tuning and 1nz strength. Better suspension (have custom lower than MI springs made for my tokico reds, or go to damping adjustable coilovers). Limited slip. I bought my Yaris as a salvage (but actually tip top, just a front bumper cover replacement really) for a good price. Zage kit + management (FIC and PnP harness) + tuning + monitoring gauges + lsd+unplanned BS in reality will cost about $4500. Do I have to kiss my front and rear oem brakes goodbye?
Potential other cars: another turbo mini, rsx-s (great setup but hard to find one that some kid hasn't turned into a shitmobile), and I just can't stand the mazdaspeed 3 so don't even go there. If there was an Abarth 500 for sale in the US, I would probably just get one. Turbo cobalt is a real performance car, but heavy....everything is so heavy nowadays. I'm a Colin Chapman kind of guy. All of my other options weigh 300+lbs more than the Yaris.
Back to the question-could the boosted and sorted 1nz Yaris fit my goals (and do it at 1000's less than a used turbo mini)? Would I be able to carefully setup and tune the car, then mostly just perform maintenance, not a never-ending research project?
Thanks for your input!!!
OTB is offline   Reply With Quote
Old 07-21-2011, 12:33 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Fiat sells the 500 (though Abarth name was dropped) in the USA now. Personally, I'd say the Mini would be a better choice if comparing the two even though the Mini costs much more. Since you already own a Yaris, I don't know if the mods you mentioned would be comparable to a Mini - Maybe the member Jason@SportsCar might be who to ask? The Forced Induction section or the Tracking, Racing, Auto-X section of this site might provide a better read for your goals. A few on this site already have the zage kit and the other alternative would be the blitz supercharger for adequate boost. They could chime in, too.
Old 07-21-2011, 04:01 PM   #3
OTB
OTB's Avatar
correction
I guess I should have said "Abarth 500 essesse" above. The regular Fiat 500....no thanks.
I'll try to lure some opinions from the forced induction and track sections-thanks.
Old 07-21-2011, 05:14 PM   #4
Jason@SportsCar
Only you know what will make you happy... But I would start with the basics and work up.
First, better suspension. Get a set of quality coil-overs. The Tokicos are not track worthy, they are an OK street shock - hint, stay away from any adjustable shock that combines compression and rebound adjustments, you will never get the damping curve where you want it. Stick with rebound adjustable shocks unless you really know what you are doing, you can really screw up a car playing with the compression settings.
Swaybars: if you get the springs and shocks right you wont need to bolt a 15lb weight to your rear axle.
Brakes: the stock brakes are overkill for the weight of the Yaris. Upgrade the front pads and leave the rest alone. If your car has a lot of miles, or the lines look suspect, get the stainless ones. We only added brake cooling ducts when we went to the 13" wheels because the airflow is so restricted, we have still never had fade - and this is with a 40min race, not a few hot laps.
Trans: this makes the car, you must get an LSD. If you have the money get the OS Giken, if you want to go cheaper get the TRD unit. BUT while you are in there install the xB 4.312 final drive, it really wakes the car up. You will already be paying the labor (or doing the work) to pull the stock gears when you install the LSD, it is not much more work to swap the gears.
Tires/wheels: 13" wheels make the car a rocket. They give you an even shorter final drive, lower the cg (and help get the roof down out of the air), they are also a lot lighter than the big stuff. Another advantage is you can run a wide 13" tire without it bashing the fenders, no need to cut or roll.
Bolt-ons: Get the header, intake and ecu. You can really unlock some power.
That alone should be enough to take out any stockish Cooper S. If you are not satisfied at that point you have all the basics covered, and now you add the FI.
As far as a radiator, the Mishimoto xB unit pretty much drops right in (you have to drill two holes in the core support), and we used the xB hose set.
Old 07-21-2011, 06:11 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Just in time
Old 07-21-2011, 06:13 PM   #6
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I have seen more than a few Abarths here in SC ...
Old 07-21-2011, 06:25 PM   #7
Jason@SportsCar
They are all over the place... It takes more than a set of stickers to make a car a model that is not sold here. Yet. There are certainly "tribute" cars out there. Fiat even lets you order the 500 with some stickers.
Old 07-21-2011, 07:11 PM   #8
Jason has a good answer, although I swear by my sway bar; seems to work really well with my set up.
Add a light flywheel when you put in the diff and final drive.
Old 07-21-2011, 07:44 PM   #9
Jason@SportsCar
How the hell did I forget the flywheel.
Your rear bar works because your rear shocks are to long. Shorten them up and they will pick the tire up, without the weight of the bar. Although, its likely not a very street-friendly setup.
Old 07-21-2011, 11:27 PM   #10
Focus_Sh1ft
Focus_Sh1ft's Avatar
The question here is undoubtedly what you are aiming for. A Yaris with a Zage kit isn't really going to be comparable to all the other cars you mentioned. If I were in your position though, I would turbo the Yaris. It's a crap ton cheaper than everything else being considered and the Zage kit really brings the car to life. 150ish hp may sound low but on such a lightweight car, as you mentioned, it's kinda a big deal. At this point, there's now a couple of people who have used the Zage kit so a lot of research has been done already (I wish I could have had that luxury).
I know you're talking about tracking it, but I can at least testify as to how awesome of a daily driver the Yaris is turboed. It's so much damn fun, and I'm still achieving 30+ MPGs.
Old 07-22-2011, 11:00 AM   #11
OTB
OTB's Avatar
Thank you guys-
I appreciate the input. I'll have a look at 4.xx final drive and lsd units. The flywheel feels so light on the stock yaris (heel-toes are just a tiny blip), I hadn't even considered there's lighter ones out there. Since the Yaris makes no torque out of the hole, does the lighter flywheel make streetability really suck (like starting up a hill, etc.)?
Suspension wise-I don't think I could handle the spring rates necessary for pitching the boat anchor (swaybar), due to the car being a street car. Damping adjustable coilovers w/spring rates similar to my MI springs would probably be my route.
Brakes-good to hear! Just like my MR-S, with the right pads, the stock brakes pretty much kick ass.
Wheels-I'll explore the options. 13" would be cool, especially with a smaller overall diameter tire, but for street class time attack, I'm not sure I'll find 13" compatible tires (RE-11, RT-615, Kumho XS, Star Spec, etc.) Race tires seem to be more available in funky sizes.
Again, thanks guys, I certainly studied up on Garm's posts, Jason's article in SportsCar, and Focus's install thread.
I'll try to have a good look at Jason's car at Miller and take some notes.
Old 07-22-2011, 12:19 PM   #12
I run 13x8's with Hoosier 225 R6 tires for road courses, but I think that would put me out of "street class".
Old 07-22-2011, 12:21 PM   #13
Stock is about 15 pounds, the ones I sell are 9.4. and 8.6. Big difference.
Old 07-22-2011, 12:43 PM   #14
Jason@SportsCar
Without FI power you really need gear multiplication to make the car move, it is a world of difference.
The stock setup (flywheel/clutch/pressure plate) is 26lbs, our lightened setup is 18lbs. While it is a significant difference, it is totally street-able. The problem with most race setups on the street is to aggressive of a pressure plate/clutch combo, some of them are an on/off switch. We used a 3-puck solid hub clutch (weighs 1lb), but a very mild pressure plate - its not like we are trying to hold back 300hp - so it is easy to drive. The flywheel alone wont have much impact on how the car drives, it just lets it rev more freely.
If you are going to run a street tire class the 13"s wont work, there are no options for competitive street tires (140+ tread wear) in those sizes. I would go with a 15x8" wheel, and a 225 Hankook RS3.
I don't think we are going to make Miller this year, its not in the budget.
Old 07-22-2011, 01:18 PM   #15
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I am not sure about NASA rules but i do know if you plan to autocross with SCCA and you wanna stay in Street Touring class. Dont boost. Stick to what Garm and Jason are saying..
BUT if you do boost, I think the supercharger is your best bet for the instant boost and also you are looking for only 140-150hp range. perfect setup. Then that will put you in Street Modified class. Then you can get those Rcomp tires on 13" wheels and be more competitive..
We have a guy in our region who runs a Cooper S and KILLS everyone. He is Stuart K. Scroll down to the RAW TIMES. He is running in D Stock class.. Its in the driver. This particular event he let someone else run his car also "phillip lee". that kid is a prodigy.
http://buccaneerregion.com/ce-7-11.html
some of my insight and bit of input
I like this thread, giving me some insight on future plans for the yaris. thanks!
Old 07-22-2011, 01:42 PM   #16
That's a great set up. My Stage 4 clutch is a little twitchy for the street.
Old 07-22-2011, 01:46 PM   #17
Jason@SportsCar
Well you do have about twice as much power as us.
Old 07-22-2011, 03:12 PM   #18
^ yeah and half the skill.
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
