Old 07-22-2011, 12:50 PM   #1
Dperry
Dperry's Avatar
Drives: 2007 black yaris hb
new mid pipe
just got my nitto midpipe and o2 fouler from garm...this is a nice piece of stainless. i currently have the dc axleback and notice i get small backfires more like a light pop gurgle noise...once i find time to install the mid pipe will i have a lot of backfire and flutter gurgle noise?
Dperry is offline   Reply With Quote
Old 07-22-2011, 01:11 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
probably
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-22-2011, 01:39 PM   #3
I doubt it - so there are your two answers, go put that thing on!
Old 07-23-2011, 01:49 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
So I take it you final got your cargo container and have the mid-pipes in stock again ??? Please Pm me a shipped price to 92020 thanks Garm
Old 07-23-2011, 09:42 PM   #5
Dperry
Dperry's Avatar
so bad news for me the orginal bolts to the exhaust r rusted on and lack of tools screws me again...i believe the bolt head is 13mm because 14mm is too big but its so rusty i cant fit a 13mm on it. i wish the midpipe came with new bolts...sad face. ne input would b helpful at this point to getting the rust-welded bolts off.
Old 07-23-2011, 09:51 PM   #6
Soak the heck out of them. I used "knock'er loose penetrant" and keep spraying the heck out of them every couple of minutes for about an hour, before breaking them loose with a 14mm socket and a 3' piece of pipe on the ratchet. They are definitely 14mm, but yours may have corroded enough to reduce the head size.
Old 07-23-2011, 10:19 PM   #7
Dperry
Dperry's Avatar
yea 14 mm just spun around the bolt head so i think im beat... why would toyota use a metal that will rust under the car BULLSHIT!
Old 07-23-2011, 10:32 PM   #8
Dperry
Dperry's Avatar
does ne one kno the thread size so i can buy new bolts wen i get these shitty ones out
Old 07-23-2011, 10:54 PM   #9
I believe that they are M10x1.5. If you buy stainless, make sure they are grade 8.
Old 07-24-2011, 08:52 AM   #10
Dperry
Dperry's Avatar
has anyone used the oem spring and bolts to install midpipe?
Old 07-24-2011, 01:27 PM   #11
schragen
Onyx Edition
schragen's Avatar
Drives: Yaris 3DR Onyx Edition
i literally just installed my midpipe yesterday from garm, exact same exhaust setup as you...
1. i used 3/8x1.25 bolt with 2 3/8 washers each 2 locking washers and 2 nylon lock nuts for the middle part where the midpipe seperates...other than than i used the oem exhaust springs
2. it was slightly off and the front part of the midpipe didnt quite fit over the gasket so i left the front gasket off to bolt it up to my turbo's downpipe
3. i still get popping but its on purpose...when you hit high rpm's and shift and immediately get back on it...it WILL pop and gurgle...if youre driving conservatively it shouldnt gurgle or pop ever
schragen is offline   Reply With Quote
Old 07-24-2011, 08:26 PM   #12
Dperry
Dperry's Avatar
ok got the nitton mid pipe on had a lot of problems because of the rusty bolts so had to make my own bolt spring set-up. got a new crush gasket from manifold to midpipe, used paper gasket to join the two midpipe sections....and got a crush gasket for the mid pipe to axle back but that gasket was way to large for the axleback inlet. so heres my question does anybody know the inlet dimensions for the dc sport exhaust or the correct size crush gasket for that application thanks
Old 07-25-2011, 02:58 AM   #13
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
My bolts are all rusty too,easiest way to knock the rust loose is any product like PB Blaster or such and spray them and let them sit a few and spray again,tapp lightly with hammer,spray more,start car once or twice to heat and that draws the blaster through a bit as the bolts swell and shrink.....
I got my install coming up this weekend and am excited.....also on the o2 sensor we found using nickel anti sieze on the threads helps in the future to get back out again,little goes a long way.
Most times picking up a few differant lengths of bolts and washers and nuts and such helps,I have gotten awy not using the springs a few times,but they are there to remove stress or something on the bolt and pipe and such,it has a function,I just dont know how to explaine it.
Old 07-25-2011, 10:25 AM   #14
Dperry
Dperry's Avatar
i made my own spring bolt combo cuz all the bolts were so rusted that they were not usable again. now i just gotta get a crush gasket to go were the axle back meets the the midpipe and i dont kno what size i need.
Old 07-26-2011, 11:51 AM   #15
Dperry
Dperry's Avatar
no more exhaust leak and i think it sounds pretty damn good, still very deep just more throaty. im so happy it still doesnt sound like a civic! next dc headers.
new DC HEADER & used NITTO MID PIPE ! annn Items for Sale by private party 9 03-27-2011 03:33 PM
Nitto Mid Pipe Size???? hatchbackkid82 Performance Modifications 8 12-07-2009 08:24 AM
STOCK MID PIPE ***WTB*** shinlee Willing to Buy by private party 4 07-14-2009 07:25 PM
mid pipe swap shinlee Performance Modifications 0 02-09-2009 10:44 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
