Old 07-24-2011, 01:16 PM   #1
canadian_princess
canadian_princess's Avatar
Drives: '07 Yaris Sedan 'S'
Send a message via Yahoo to canadian_princess
Exclamation which is cylinder 1 on my '07 sedan?
I just got my oil and spark plugs changed yesterday and now the check engine light is on. Plugged in the obd sensor and I got the code P0301, which thanks to garms code list I found on the forum came up as cylinder 1 misfire. One of the spark plugs were dropped yesterday before installation. When the car is idle it feels unsteady. 500rpm. Ideas? This was the first time i believe these plugs have been changed, at least since ive owned it in Dec (08).
canadian_princess is offline   Reply With Quote
Old 07-24-2011, 01:26 PM   #2
Revsson
Just looking at the Ignition pdf:
http://www.etimago.com/yaris/repairmanual/Ignition.pdf
It would appear that #1 is closest to the battery or driver's side in the USA.
However, you might want to wait for the experts to chime in.
Old 07-24-2011, 01:39 PM   #3
bronsin
bronsin's Avatar
My guess is #1 is the one you dropped.
Replacing the dropped plug with a new one would be the first thing I would do to resolve the issue.
Old 07-24-2011, 01:42 PM   #4
Revsson
Hmm, just looked at the EWD:
http://www.etimago.com/yaris/repairmanual/EWD.pdf on page 48,
and it shows the opposite. So, don't go by me.
Old 07-24-2011, 01:43 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
Number 1 is typically closest to the crank. So its going to be farthest left when looking down at the engine.
Old 07-24-2011, 01:46 PM   #6
canadian_princess
That's the one that was dropped. Furthest to the left. Thank u! Keep the info coming!
Old 07-24-2011, 05:53 PM   #7
bronsin
bronsin's Avatar
You GOT the info!
love the av.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
2009 YARIS sedan : oil leak from #1 head cylinder Hershey General Yaris / Vitz Discussion 5 01-03-2011 01:18 PM
