Old 07-27-2011, 10:08 PM   #1
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
1nzfe and 1nzfxe parts interchange?
I was surfing around tonight and saw where the static compression ratio of the prius engine was 13:1. It said that the cam timing bled off the excess pressure to make a streetable engine.
What are the odds that you could use prius parts to build a high performance 1nzfe?
Old 07-28-2011, 12:34 AM   #2
^ different kind of engine set up the way the pistons work. A search will probably turn up the previous threads about this.
