#1 |
Drives: Yaris t spirit Join Date: Jul 2011
speedometer lighting
Could any one tell me if there is a way of making the lighting brighter on the speedo etc during the day on a 2011 yaris T spirit, when bright sunlight shines in it makes the dash lights sometimes unreadable, thanks
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Have you checked the brightness control wheel to the left (right?) of the steering wheel? I normally use my headlights during the day to increase visibility, but the default brightness for night time driving isn't bright enough to see. If you scroll the wheel all the way up until it "bumps" over the soft stop, they will go to daytime brightness.
Which lights on the dash are you having a hard time seeing? You should be able to see the speedo regardless, so the only other thing you'd see on a regular basis would be turn signals and hi-beam. Last edited by CrankyOldMan; 07-28-2011 at 08:55 AM. Reason: oops, might be a righthand drive. |
| Speedometer Accuracy? | YarisPete | DIY / Maintenance / Service | 37 | 11-29-2013 02:00 PM |
| speedometer | walt101786 | Cosmetic Modifications (Exterior/Interior) | 0 | 10-09-2010 09:03 PM |
| No speedometer or tachometer lights during day | cdavidhess | DIY / Maintenance / Service | 20 | 06-30-2009 10:38 AM |
| Interior Lighting | Typer73 | Cosmetic Modifications (Exterior/Interior) | 3 | 05-08-2007 05:34 AM |
| ambient map lighting? | atebit | Cosmetic Modifications (Exterior/Interior) | 0 | 11-05-2006 01:15 AM |
