Old 07-29-2011, 02:58 PM   #1
bigjohn2ca
Fire Dancer
bigjohn2ca's Avatar
Drives: 2008 Yaris S HB
Water leaking into cabin...HELP!!
I've noticed 2 things:
1)When I have my AC on, on left turns, there's a strange noise coming from the right side of my engine...
2)When I have my AC on, on left turns, there's water leaking into the passenger side under the dash out of area behind the glove box.
Any advice? I don't want to take it into the dealer/shop unless I absolutely have to.
Eat, Drink, and Be Merry
bigjohn2ca is offline   Reply With Quote
Old 07-29-2011, 03:04 PM   #2
There are threads in here somewhere on this. Try searching 'A/C leak water' and see what turns up.
Old 07-29-2011, 03:09 PM   #3
bigjohn2ca
Fire Dancer
bigjohn2ca's Avatar
Thanks yo!!
Old 07-29-2011, 04:10 PM   #4
LittleRed
LittleRed
Drives: 2008 Yaris Hatchback 5spd
I have found that on hot and humid days if i leave the knob on recirc... it bulids up condensation inside and will leak on the passenger side.... if u put the setting to fresh air right after the car cools down this will not happen.... it hasen't happened again after i stopped leaving it in the recirculating setting for long periods of time... hopefully it will for you too.... good luck..
LittleRed is offline   Reply With Quote
Old 07-30-2011, 04:57 PM   #5
auxmike
auxmike's Avatar
Could the drain tube be blocked?
Old 07-30-2011, 06:31 PM   #6
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
1 unclog a/c drain hose
2 drop fan motor and clean throughly of any debris
3 buy and install CAF
OTA'sTOY is offline   Reply With Quote
Old 07-31-2011, 12:48 PM   #7
AppleJacks716
Drives: 2010 5 Door
Sounds like clogged drain hose.
AppleJacks716 is offline   Reply With Quote
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
07' HB Water Accumulation in hatch bobolinko General Yaris / Vitz Discussion 9 09-26-2010 02:55 AM
water in the tails? the_boss Cosmetic Modifications (Exterior/Interior) 9 02-20-2009 12:53 PM
