Old 07-30-2011, 07:41 PM   #1
CGriswald309B
Drives: 2008 hatchback
Grinding when making a turn.
Ok, first and foremost thanks in advance for any advice, help, and/or suggestions. I know very little about cars but I remember coming here a few years ago before I bought my Yaris and everyone seemed helpful.
About 2 months ago I had new tires put on and had a realignment. I then made the trip back to Austin from my hometown in PA (about 1500 miles). About 8 hours into the trip I noticed a loud grinding noise whenever I cut the wheel hard to the left. Now, I typically have music on pretty loud so it could have happened earlier. I didn't hit any curbs, large pot holes, etc.
Anywho, I looked under the wheel well (that is the correct term, right) and didn't see anything too out of the ordinary. I did seem to me that maybe they didn't reattach the plastic correctly (see attached pic). I just assumed it was the wheel rubbing up against a piece of plastic. My concern is that it may be something worse. The thing is I've already driven it about 1200 miles since I've heard the noise.
So, any thoughts and or suggestions?
As always, many thanks in advance.
Oh yeah, I have a 2008 hatchback with about 32,000 miles.
File Type: jpg 278109_10150323246771760_568931759_9907891_7300114_o.jpg (95.9 KB, 124 views)
CGriswald309B is offline   Reply With Quote
Old 07-30-2011, 08:34 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
If you Yaris is lowered it is likely tire rub.
You might list your suspension mod's and tire size to help us diagnose.
Old 07-30-2011, 09:45 PM   #3
CGriswald309B
First, thanks for the quick response.
Second, I have no idea what my suspension mods are.
Third, the tires are 15 inches.
Old 07-31-2011, 09:48 AM   #4
thepartsmancometh
Drives: '08 LB, '07 WRX
a loose inner fender well can certainly make a nasty noise, and that is the most likely thing. The tire/alignment shop probably would not have had this off for any reason. . By suspension mods, what he means is whether the car is stock, or if you have changed the suspension with aftermarket parts.
thepartsmancometh is offline   Reply With Quote
Old 07-31-2011, 01:32 PM   #5
CGriswald309B
The car is most definitely stock. The only adjustment I've made is putting a hula girl on my dash.
Old 07-31-2011, 02:15 PM   #6
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
What is the width of your wheels?
MickZEL is offline   Reply With Quote
Old 07-31-2011, 04:03 PM   #7
Lil Abner
Drives: 2009 3dr LB Manual
So you purchased the car, but only added a hula girl and tires. Are you positive the car isn't lowered at all? How to tell, either it has a LOT of gap in the fender, or it doesn't.
If you think the tire is rubbing the inner fender where you took the picture, try putting a piece of grey duct tape in that area. Drive the car. Look at the tape. You should be able to see marks on the tap if it is rubbing.
Also, is there any fender damage in that area? A small dent/push from a car door or anything?
Another thing, the noise, does it sound like metal or plastic noises? You should be able to tell the difference. Know what type of noise it is will help in determining the problem.
Old 07-31-2011, 04:09 PM   #8
CGriswald309B
@MickZEL - Sorry, but I have no clue.
@Lil Aber - I would say there is a good bit of room. And I do have grey duct tape so I will go do that in a few minutes. No dents, bumps, etc. It definitely sounds like plastic.
Old 07-31-2011, 04:19 PM   #9
thepartsmancometh
more than likely, something impacted the inner fender well (like you hit a stick in the road or something) and that caused the lining to come loose. If its loose, it may drag, whether lowered or not. the tape idea is a sound one. is there any other visible damage (and pics thereof)?
Old 07-31-2011, 04:25 PM   #10
CGriswald309B
No other visible damage. I'm heading down to put the tape on my car now. I have to run some errands and visit a lady friend. When I return I'll let you know what happened.
Thanks guys!
Old 09-05-2011, 08:01 PM   #11
CGriswald309B
Sorry for taking so long to respond. To be honest, I completely forgot about this thread.
The grey duct tape didn't show any dirt, but I decided to tape on some white paper and sure enough it was dirty in no time.
Again, it definitely sounds like plastic grinding.
The only time it doesn't make a noise is when I am in D and turning left. Every other directions, D and R, it makes the noise.
Thanks again!
Old 09-05-2011, 08:12 PM   #12
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
check the axle, there's a rubber boot there that looks like an accordion. Make sure it's not damaged.
Old 09-05-2011, 09:46 PM   #13
CGriswald309B
I'm heading out to check the boot right now.
Old 09-05-2011, 10:37 PM   #14
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
sounds like possibly the rotor shield touching the rotor , it bends easily. Check that.
Ptuning.com
Old 09-07-2011, 12:03 AM   #15
CGriswald309B
Doesn't seem like the CV joints are damaged.
I will definitely check the rotor shield tomorrow.
Quick question. Do I have to take the wheel of to check the rotor shield?
Many, many thanks!
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
Yaris idles loudly at red lights and when making sharp turn ebowers83 DIY / Maintenance / Service 36 02-24-2009 05:03 PM
