Old 08-02-2011, 10:50 AM   #1
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
Water Pump Pulley
How the hell do I get the water pump pulley off, I looked all over the forums but can't find nothing. Its a OEM water pump not aftermarket.
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 08-02-2011, 12:20 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
jsut had mine replace under warranty.. 2 ways of doing it.. underneath toyota had to take out the ac compressor though.. or on top but need the alternator off completely.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 08-02-2011, 01:45 PM   #3
Here is my DIY.
http://www.microimageonline.com/foru...1NZ?highlight=
Old 08-02-2011, 09:14 PM   #4
Vioz
alright thx for everything. just finished replacing the water pump so far it was good.
But......
I let it run for about 15 minutes, then I took it for a test drive, one thing i noticed is its idling really low at about 400-500 rpm. Then when I came back home after the test run, the radiator fan was blowing really hard and wasn't stopping for about 2-3 minutes and i turned off the car.
Is that normal that the fan is blowing so much since I put new fluids in or no?
And that low idle, that has happened in the past but is that normal as well?
a.k.a. "Aothachos"
Old 08-02-2011, 10:11 PM   #5
Once you disconnect the battery, the ecu relearns after the initial start up. It will be normal the next few runs don't worry
Old 08-02-2011, 10:28 PM   #6
Vioz
okay good. yea i just started it up again and its idling normal now but while the test drive it started to over heat came back home and all the coolant that was in the tank was gone lol i guess it took it all into the pump and such because of all the loss so i just put more anti freeze to the top and im letting it cool off, going for another test run soon once it cools down.
a.k.a. "Aothachos"
Old 08-02-2011, 10:37 PM   #7
Turn on the engine and let it run with the radiator cap off. The thermostat needs to open and allow the fluids to go in. Once it opens up add more, until full. It may take a few minutes for the thermostat to open.
Old 08-02-2011, 10:39 PM   #8
Vioz
k thx gunna do that now
a.k.a. "Aothachos"
Old 08-02-2011, 10:56 PM   #9
Vioz
alright so i have it running, it was empty again before i even started it, so i filled it up, started it up opened the cap and about 4 inches the coolant went down and i filled it up to the top again, now the fan has been on the whole time and still is, didn't drive but no overheat signal so far.
a.k.a. "Aothachos"
Old 08-02-2011, 10:57 PM   #10
Good, you should be good when the fluid doesn't go down. Then cap it and check for leaks and your good to go
Old 08-02-2011, 10:58 PM   #11
Vioz
k i turned it off and ima check it again in about 10 minutes, seems to go down everytime i have it off for a little bit.
a.k.a. "Aothachos"
Old 08-02-2011, 11:03 PM   #12
It will do that until it's full. Sounds like it will be ok for you and you shouldn't have any problems. Make sure you do have a little bit of play in the belt, not too much though.
Old 08-03-2011, 10:06 AM   #13
Vioz
everything worked out great! you was very helpful, thanks!!
a.k.a. "Aothachos"
Old 08-03-2011, 10:13 AM   #14
No problem, glad I could help.
Old 08-14-2011, 04:29 PM   #15
Richy69
Drives: Yaris liftback 2009
my yaris the light of chek engine start and i scanned and mark five code of emission someone can tell me why do that
Richy69 is offline   Reply With Quote
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
NST Lite Water Pump Pulley fmicle Items for Sale by private party 1 10-18-2010 12:01 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
