Old 08-02-2011, 06:14 PM   #1
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Speaker wiring for front and rear LB
I just bought some 6.5" fronts and 5.25" rear speakers. I searched through the forums but couldn't find a solid answer. Will the new speakers be plug and play without having to buy a wiring harness? Thanks in advance.
weedtank is offline   Reply With Quote
Old 08-02-2011, 06:30 PM   #2
isra
isra's Avatar
Drives: 2007 Yaris hb
you might have to splice the wires but the speakers r an exact fit on the car. u have to break the factory speakers in order to have to use the factory spacer.
iSRA
isra is offline   Reply With Quote
Old 07-03-2012, 07:06 AM   #3
m3177o
Drives: White Egg
if im not mistaken, you can buy speaker adapter plugs so you can just plug and play. thats if you dont want to splice. i would rather solder instead of just splicing just to secure a connection.
m3177o is offline   Reply With Quote
Old 07-03-2012, 07:50 AM   #4
LugNut
Drives: 2007 2DR Liftback
Thumbs up It works!
I'm doing this install now, and have the fronts done. I'm using Pioneer TS-G1644RR (6.25 in.) all the way around. I was able to modify the factory plastic mounts to accept the speakers, and cut and resoldered the factory wires inside to the new speakers so the factory wires/plugs, and the speaker to panel spacings are retained. The new speakers' +/- even line up nicely with the OEM-mount terminals' +/-.
LugNut is offline   Reply With Quote
Old 07-03-2012, 10:25 PM   #5
razingman
Drives: 2007 ls liftback 5 door manual
Yea just solder unless you have an amp and want real power to them then redo the wiring pretty much.
razingman is offline   Reply With Quote
Rear Speaker Placement Ideas? revolution In Car Entertainment + Electronics (audio / video / alarm) 0 06-14-2011 10:50 AM
Another question about car audio wiring for rear components YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 0 08-16-2010 09:39 PM
How to route speaker wire to rear doors? DFA In Car Entertainment + Electronics (audio / video / alarm) 2 04-04-2010 04:53 PM
rear speaker wires, help stu 1 UK 3 04-02-2010 04:41 PM
