Old 08-06-2011, 05:21 PM   #1
c-dub
Drives: 2008 yaris
how loud do water pumps get when they fail?
and what kind of noise do they make? rattle, sqeek or grinding?
c-dub is offline   Reply With Quote
Old 08-06-2011, 05:35 PM   #2
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
It usually starts with a squeak, then it becomes a louder grinding noise, and as the bearing goes, they begin to rattle due to the slop in the shaft. At that point you should see a fairly good coolant leak.
DMZ is offline   Reply With Quote
Old 08-06-2011, 05:38 PM   #3
c-dub
Drives: 2008 yaris
would you notice it if you spin it by hand?
Old 08-06-2011, 05:38 PM   #4
Cosworth
Drives: S sedan
It definitely starts to rattle. You might not notice it when cruising on the road, but it is obvious when you're parked with your engine running. If you do change the water pump, remember to put in a new serpentine belt since it's same labor.
Cosworth is offline   Reply With Quote
Old 08-06-2011, 06:53 PM   #5
bronsin
bronsin's Avatar
Check for thrown coolant on the underside of the hood. Possibly an indicator a long time before the pump packs it in.
Old 08-06-2011, 08:21 PM   #6
BLH
Drives: 2007 Yaris Sedan
When mine failed at 15K miles.
I didn't hear anything out of the ordinary.
I did see the coolant spray from front to back on the inside hood and inside the water pumps pulley.
Old 08-06-2011, 08:57 PM   #7
c-dub
Drives: 2008 yaris
here's my issue, posted in its owne thread... http://www.yarisworld.com/forums/showthread.php?t=34990
My girls 08 yaris has been making a racket from under the hood it Sounds like a knocking coming from the passenger side where the accessories are. Its stays constant at idle and when you raise the rpms.
I Pulled the accessory belt off and the noise went away. Put it back on and it was back. Pulled out a stethoscope and tried to listen for anything out of the ordinary on the a/c, alt and water pump. Think I can hear the noise coming from the water pump. Every thing else sounded normal, but I can hear the rattle when I put the scope on the water pump near the pulley just not as loud. Any ideas? Will a water pump make that big of a racket?
Old 08-06-2011, 08:59 PM   #8
c-dub
Drives: 2008 yaris
didn't notice any anti-freeze when i looked at it, but will check again
Old 08-06-2011, 10:14 PM   #9
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Yes. When it gets bad it's pretty noisy. You need to replace it. Get a non-Toyota aftermarket brand. Check some of the other water pump threads for recommendations on which to choose.
Old 08-06-2011, 10:53 PM   #10
c-dub
Drives: 2008 yaris
yep, been reading all day
Old 08-07-2011, 01:08 AM   #11
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Some of the aftermarket ones are so cheap it's suspicious though, but they do however LOOK sturdier
Old 08-07-2011, 08:01 AM   #12
c-dub
Drives: 2008 yaris
just found this on youtube...
http://www.youtube.com/watch?v=M_ggV2MSxTM
... sounds just like my girls ride.
Old 08-07-2011, 08:04 AM   #13
Klink10
Klink10's Avatar
Wow another close yaris owner. Live in Fayetteville also and had my pump go out. Noticed long before it got serious by the spray sign under the hood. Easy change at my shop. Give a holler if you need assistance.
Old 08-07-2011, 09:15 AM   #14
bronsin
bronsin's Avatar
What is the drill to loosen the suspension and drop the engine so you can get the wp in and out? Is that what you do drop the engine?
Or is it something else?
Or is there a way without dropping it?
Thanks!
Old 08-07-2011, 10:37 AM   #15
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
easiest way is to check the inner side of the pulley you should see pink stuff if its busted cause by leak
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 08-07-2011, 01:57 PM   #16
c-dub
Drives: 2008 yaris
got it done this morning. didn't see alot of pink until i pulled the a/c pump, but the bay is so dirty it was easy to over look the spray/dirt on the hood. i didn't have to drop the motor, just slide it back about 1/2" using a breaker bar btween the mount and head. didn't need to use any force it moved real easy. got all the parts from napa, in stock and could have done the hole job from the hood without getting under the car if not for the lower bolt and running the new belt.
Old 08-07-2011, 02:51 PM   #17
Altitude
Altitude's Avatar
Good job c-dub. Glad you got it sorted out!
Old 08-08-2011, 09:37 AM   #18
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I'm not sure what year Toyota started the 5 year/60K powertrain warranty, but water pumps are covered. It says this in the 2010 warranty book I have.
DebbyM46227 is offline   Reply With Quote
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
fail fail fail thebarber Off-topic / Other Cars / Everything else Discussions 10 05-20-2011 10:29 AM
07' HB Water Accumulation in hatch bobolinko General Yaris / Vitz Discussion 9 09-26-2010 02:55 AM
Wine of Water Benggolf2 Off-topic / Other Cars / Everything else Discussions 4 12-25-2009 02:01 PM
water in the tails? the_boss Cosmetic Modifications (Exterior/Interior) 9 02-20-2009 12:53 PM
