Old 08-08-2011, 08:12 PM   #1
romram
Drives: yaris hatchback
rubber boots from compartment
hi,
found this boots at the compartment from my new car.
It's still in plastic, but don't know where should it be place.
any idea?any pictures where to put it?
thanks
romram is offline   Reply With Quote
Old 08-08-2011, 08:36 PM   #2
Jason@SportsCar
Under the car in front of the back tires (look under the rocker, behind the pinch weld) there are a pair of slots that accept a T-hook, these are used when transporting the car, those caps fill the holes. Note the pre-deliver directions of the package that the dealer failed to follow.
The front holes are in the fender well near the inside edge of the rear tire, but don't require plugs.
Old 08-08-2011, 09:06 PM   #3
romram
thanks...any picture?
Old 08-08-2011, 09:07 PM   #4
auxmike
auxmike's Avatar
Oh, man.... I hope you did'nt drive around in the rain minus those plugs. Water will come right in through the floor. Everyone should check for these!
Old 08-08-2011, 09:07 PM   #5
romram
what happen if i don't plug it?or if the rubber boots falls off? any issue?
Old 08-08-2011, 09:10 PM   #6
Jason@SportsCar
That is not the case, it is open to the inside of the rocker, not the inside of the car.
Old 08-08-2011, 09:37 PM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
nothing will happen.. maybe some wind noise under certain conditions like a whistle or sound when you blow in an empty bottle. Dealer is suppose to put those in when they come off the truck. but sometimes they are missed. U can install them yourself
Old 08-08-2011, 09:44 PM   #8
romram
WOW!!! nice picture. THANKS ALOT!
Old 08-08-2011, 10:53 PM   #9
Revsson
That's a great pic!
Where did you find that.....and don't tell me you took it yourself!
Old 08-09-2011, 04:56 AM   #10
ilikerice
ilikerice's Avatar
Damn.. I was gonna say that I have a glass floor in my garage over my basement.
I actually just typed "yaris underbody" in a google search and just clicked on "images". brought me to a cool website that has various digital art, a good bit is prius and lexus cutaways.
http://www.josclaesen.be/page2.htm
Old 08-09-2011, 07:49 AM   #11
grelise
Drives: 07 YR Yaris 5dr Hatch
Haha, those plugs have been sitting in the glove box since I bought it, thought they were there as spare grommets.
Well, there in now!!
grelise is offline   Reply With Quote
Old 08-09-2011, 09:56 AM   #12
For anyone wondering what they are for - The plugs cover two holes that are used to strap the Yaris down during shipping:
Name:  Tie Down Points.jpg
Old 08-09-2011, 07:23 PM   #13
romram
NOW, it's not only me!!! Are there others??? haha!!!
Old 08-09-2011, 07:33 PM   #14
auxmike
auxmike's Avatar
I could swear I read on here somewhere that someone had water getting in due to a lack of these. That's when I checked to see if I had mine .
Sorry for the mix up, I guess....
Old 08-09-2011, 07:35 PM   #15
romram
hope you can still find the link....
Old 08-09-2011, 08:33 PM   #16
Not from the oval ones. The wet mats issue is from the round ones under the rear floor mats not being installed.
Old 08-15-2011, 06:43 PM   #17
romram
are there space/hole infront of the rocker, where water can enter? if it's a tight hole, so better to lubricate it with wd-40 or oil to prevent that from rusting ? moisture might cause it to rust?
MY RUBBER BAND BALL! AGHHH!!! Sodium Duck Off-topic / Other Cars / Everything else Discussions 47 03-06-2009 01:56 AM
rubber protector sheets? enobmort42 Cosmetic Modifications (Exterior/Interior) 0 02-25-2009 10:41 AM
source for intake coupling rubber boot. andruboz Performance Modifications 5 01-23-2009 03:30 PM
Rubber plugs in glove box cfiimei DIY / Maintenance / Service 5 01-06-2009 04:48 AM
