Old 08-16-2011, 07:23 PM   #1
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
weird thumping?
I recently bought 4 tires from Costco. They installed and balanced the tires but no alignment. After a few days, I got the bolts tightened. After driving about 200 miles after the installation, I now hear this low thumping coming from the rear of the car. Could this come from not having an alignment?
yours_falsely is offline   Reply With Quote
Old 08-16-2011, 07:44 PM   #2
No. Other than that, I got nothin'.
Old 08-17-2011, 08:12 AM   #3
Vinceb
Drives: 2008 5 Speed Sedan
check to make sure your spare is screwed down tightly in the trunk and make sure the tire wrench isn't loose and banging around ?
Vinceb is offline   Reply With Quote
Old 08-17-2011, 09:38 AM   #4
bronsin
bronsin's Avatar
Could be lug nuts not tightened.
Could be tread squirm/defective tires. Look at the tread. If its squiggles its a bad tire.
Could be loose wheel weights used to balance the tires.
I fell safe in saying its NOT alignment cause it started thumping AFTER they installed the tires.
Good luck...tell us what you find out!
Old 08-17-2011, 05:21 PM   #5
yours_falsely
Spare is tight. wrench is secured. I checked the lugnuts today and they all seem tight. I was thinking that maybe they weren't balanced quite right but I wasnt sure if that would cause the problem. I'm gonna go out and check the tread now.
Old 08-17-2011, 05:29 PM   #6
sex
sex's Avatar
Drives: 09 5DR
Costco should have free balance and rotation. You can have them rebalance or rotate or both. Is it noisy at all speeds? Periodic noise or intermittent? During acceleration/braking, turning, and in a straight?
Old 08-17-2011, 07:37 PM   #7
Lil Abner
Drives: 2009 3dr LB Manual
Yeah, bring them back and have them re-checked for balance issues.
Old 08-17-2011, 11:35 PM   #8
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
I dunno, sounds like a bad tire to me. I always feel there are places to save money, but tires ain't one of them...
Old 08-18-2011, 09:41 AM   #9
yours_falsely
They balanced them when the tires were installed. I hear it at all speeds however it is quieter. Acceleration, braking, turning and straight, the sound is there all the time. I would take it to costco but I'm now at college and even if i could find a costco around here I don't have the membership card. My parents do. Looks like i might have to pay someone to check it out.
Old 08-18-2011, 10:48 AM   #10
It could just be the new tires are noisy. I have some old Parada spec 2 yokohama's on my old Honda and they make SOOO much noise it's insane. Sounds like my wheel bearings are ready to explode.
Old 08-18-2011, 01:39 PM   #11
yours_falsely
i feel like new bridgestones shouldn't be that noisy. Idk for sure though. I certainly hope not though.
Old 08-18-2011, 09:15 PM   #12
Lil Abner
Well, just because they balanced them, doesn't mean they are currently balanced! The weights used are often stick-on ones, so it's possible a small one fell off in the back. Because it's the rear suspension, you wouldn't feel it as much as the front.
Old 08-19-2011, 06:04 PM   #13
yours_falsely
So after troubleshooting for days I felt I missed something and headed to a local tire shop. I explained the issue and they took my yaris around back. 15 minutes later, the guy comes back with a screw in his hand. Apparently this is what was causing the problem. Wow. Thanks everybody for your help lol
Old 08-19-2011, 06:19 PM   #14
Lil Abner
A screw IN the tire tread?? Ouch. But that would explain it...sort of. I've had a tire in my tread, and never heard it. You must have good hearing!!
Old 08-20-2011, 10:53 AM   #15
yours_falsely
Yeah it was in the tread. I wasn't the only one who heard it though. And it was a decently large screw. Had I not had new tires I probably would have a flat.
Old 08-20-2011, 07:04 PM   #16
Revsson
Just a screw?...and here I thought it was someone stashed in your trunk who
wanted to get out.
Thanks for keeping us updated on the final cause.
Old 08-20-2011, 08:11 PM   #17
bronsin
bronsin's Avatar
So...they guy took the screw out of the tire? And its still holds air?
Like...how long was the screw? I mean you better check your tire pressure over the next few days to make sure you dont have a slow leak.
Just because a tire is new doesnt mean it cant have a puncture.
Old 08-22-2011, 01:13 AM   #18
yours_falsely
Yeah he took it out and gave it to me. pressure seems fine so far. I guess we'll see how it holds up.
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
Weird door locking problem, electrical? davembfan General Yaris / Vitz Discussion 19 09-30-2009 02:50 PM
Weird rattle coming from teh egg. Impresive-G DIY / Maintenance / Service 14 11-10-2008 03:22 AM
this is weird..maybe i should put mine up on ebay hasher22 Australia 1 06-16-2007 09:40 AM
