#1 |
![]() ![]() Drives: Yaris Hatchback 2012 SE Join Date: Aug 2011
A/C PROBLEM
Hi guys I buyed a yaris HB 2008 last week with 29000 miles on it, I noticed that after driving like 30 to 40 minutes the a/c stops blowing cold air and blow cool air. I have to turn it off and wait like 5 minutes and then it starts to work again...anybody know what it could be?
thanx |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
Sounds to me like you are a little low on Freon. Small can from an auto parts store would do fine for you. it is not hard if you get the one with a gauge with it... just fill till the upper part of the green and do not go into the red zone. It'll work all good again. |
#3 |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
Sounds like one of your lines are icing up, had a similar situation with suzuki van. When I checked, the line was iced up then I would turn off AC. Once the ice melted from the heat, AC would be good again.
#4 |
It's possible the condenser is icing up after long use. Are you blasting it at full speed for 30-40 min? There also might be a clog in the drain line.
#5 | |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| A/C sometimes won't start? | Greedo51 | DIY / Maintenance / Service | 5 | 07-23-2016 08:50 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
