Old 08-19-2011, 05:02 PM   #1
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
The stock o2 sensor is a wideband
I figure this is the best place to put this info. I won an aftermarket wideband in a contest and said screw it and installed it on the Yaris for s & g's. Few observations of note:
- 14.5-14.7 AFR is the cruising and idle target
- The o2 readings DO NOT oscillate during cruise. They reach the target and move .1-.2 points one way or the other to maintain the target. Narrowband sensors do not do this
- From what I can tell, the computer adjusts very fast and very accurately. Was very surprised to see this behavior
- Open loop WOT with the stock intake drops the AFR to 12.5 (rich). After installing my Injen CAI, the target raised to 13.1. Stock airbox is a major restriction on this car. Very noticeable difference between the two
- AFR richens up to a mind boggling 10.9 with the stock airbox right before and up to redline. With the intake its like 11.3 or so (I can't exactly remember, only did it once or twice)
From what I can tell, with just a proper standalone/piggyback computer this motor could easily pull 115-120whp with tuning and regular I/H/E upgrades.
The Spectacle is offline   Reply With Quote
Old 08-19-2011, 09:16 PM   #2
auxmike
auxmike's Avatar
Did you use Scangage II?
Old 08-19-2011, 09:45 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
That could be because the yaris utilizes air fuel ratio sensors which is wide range. More expensive and more acurate. Where as oxygen sensor is more narrow range. The one after the cat is probally regular o2 sensor.
Old 08-19-2011, 10:55 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
We noticed this when I was attempting my first few tries at calibrating my FIC
Old 08-19-2011, 11:11 PM   #5
The Spectacle
Drives: 08 BSP LB
For monitoring all the stock sensors and gas mileage, yes. To monitor the wideband, I have a gauge
Agreed. Primary o2 is wideband, secondary is narrow
Old 08-19-2011, 11:45 PM   #6
Primary is not an O2 sensor, it's a A/F ratio sensor. But the secondary is an O2.
Old 08-20-2011, 07:08 AM   #7
The Spectacle
Drives: 08 BSP LB
Edit: My Echo has 2 O2 sensors. That's what makes the Echo/Xb/Xa easier to tune. The computer is dumber than the Yaris.
What are you talking about? That makes absolutely no sense whatsoever.
Old 08-20-2011, 10:01 AM   #8
thepartsmancometh
Drives: '08 LB, '07 WRX
almost all newer toyota's use A/F sensors in the front position(2) and O2 after cat. The A/F's aren't exactly cheap, but they have their benefits.
thepartsmancometh is offline   Reply With Quote
Old 08-20-2011, 10:02 AM   #9
I re-edited my post to be less confusing for you.
Old 08-20-2011, 10:16 AM   #10
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Just to clear something up for myself...if the primary is A/F, why am I looking for a gauge with it's own sensor? Can I just run a gauge only and be done with that?
This is in regards to my turbo install coming up, gauges are all I need at this point.
-Type 07 FFL-
My odometer 03/11
Old 08-20-2011, 11:07 AM   #11
from the original post that looks to be all that's needed.
Old 08-20-2011, 12:04 PM   #12
The Spectacle
Drives: 08 BSP LB
Still confusing as all hell but I think I understand what you're trying to say. Both sensors are o2 sensors but only one has a range wide enough to read A/F, while the other can only read rich or lean. Most aftermarket wideband o2's are 0-5 volts and stock narrowbands 02's are 0-1 volts.
I wouldn't mess with the stock o2. Who knows what the voltage ranges for that sensor are and how the ECU reads them. Your best bet is going the route I did, unless you can find a OBD2 reader than can pull A/F from the OB2 port.
I got my gauge from Prosport http://prosportgauges.com/
Old 08-20-2011, 12:05 PM   #13
The Spectacle
Drives: 08 BSP LB
To be 100% clear...I am not pulling my readings from the stock o2 sensor itself. My gauge is reading from an independent sensor that's installed near the stock o2 port on the header.
Old 08-20-2011, 12:56 PM   #14
ok, I'll dumb it down as much as I can.
The first sensor in the exhaust located in the manifold is called an AIR/FUEL RATIO SENSOR. NOT AND OXYGEN SENSOR. The second sensor in the exhaust located after the catalytic converter IS call an Oxygen Sensor.
The job of the A/F Ratio Sensor is to adjust fuel delivery to maintain set parameters from the ECU. This a very fast and sensitive sensor.
The job of the Oxygen Sensor is to make sure the Catalytic Converter is doing it's job. This is a slow acting narrow range sensor.
The Yaris has a more sophisticated ECU compared to the Echo and can more accurately control fuel delivery based on more accurate readings from the AFR sensor.
Old 08-20-2011, 05:02 PM   #15
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Bluevitz is absolutely correct.
pre-cat is an Air/Fuel sensor. post-cat is the Oxygen sensor.
Old 08-20-2011, 06:27 PM   #16
^ The first one is actually a hybrid design, but that's getting pretty nitpicky.
Old 08-20-2011, 06:28 PM   #17
The Spectacle
Drives: 08 BSP LB
No he's not. A/F sensors ARE o2 sensors! What the hell do you think the sensor is reading? Magic fairy dust?
You're arguing semantics with me and its making my head hurt.
Old 08-20-2011, 07:05 PM   #18
ilikerice
ilikerice's Avatar
Ok, I will agree there. Most people do refer to those sensors as O2. I was trained by toyota that they are a/f sensors. Which you are correct, is just a wideband O2 sensor.
So to get this thread back on topic. YES, toyota has been using a wideband O2 sensor for the past 15 years.
A few stock parts kac Items for Sale by private party 14 10-05-2009 04:37 PM
STOCK SEATS OUT OF HB / stock tires/rims mrrock Items for Sale by private party 19 08-19-2009 04:56 PM
Stock Yaris Stuff regal Items for Sale by private party 10 06-09-2009 04:53 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 04:19 PM
Stock Parts for Trade! Yarice Items for Sale by private party 0 04-17-2009 10:23 PM
