Old 01-24-2007, 08:10 PM   #1
davidcraig2003
Door speakers not working =[
Hey!
Got a Yaris T2 on Saturday. 2 years old. Im 17 - not bad for a first car Only downside is, theres 4 speakers, the 2 dash mounted, and the 2 in the doors, these two arn't working. Any checks i can do on them without pulling apart the door?
Think i'll end up putting in electric windows/remote central locking, hopefully find someone with a bit of electronics knowledge to do it though, as god knows what i'd end up doing to it
davidcraig2003 is offline   Reply With Quote
Old 01-24-2007, 09:04 PM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Hmmm check if the "fade" option is not set to the rear speakers only. I remember i did that and i was freakin out why my front speakers wasnt workin.
If that doesnt work, then u have to pull apart the door panel and see if the wires are connected and such.....
theres some insight of it
Old 01-24-2007, 09:14 PM   #3
davidcraig2003
Its a 3 door, so theres only 2 dash mounted, and 2 at the bottom of the doors, so the fade options out as theres no rear speakers
dismantling the door.......i was afraid of that =[
Old 01-24-2007, 10:46 PM   #4
uncleyaris
I maybe unfamiliar with your version but are you sure of the dash mounts? In North America only door and rear in the hatchback?
UY
Old 01-25-2007, 02:55 AM   #5
davidcraig2003
Definetly yeah, they're on the dash up by the windscreen.
Old 01-25-2007, 07:53 AM   #6
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
but there is still a fade control even though there are no rear. the rear speakers are considered the door speakers
d2dailly is offline   Reply With Quote
Old 01-25-2007, 09:11 AM   #7
davidcraig2003
Thanks for the replys
The only option available was the balance, to switch between the left/right speakers.
Old 01-25-2007, 05:43 PM   #8
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Originally Posted by davidcraig2003 View Post
Hey!
He probably doesn't have what North America calls a Yaris. It's two years old, so I think he has what Canada got as the Echo. Anyway, our Echo was a 2003 five door and had four speakers where you say. With the stock MP3 deck, we did have a fader control. Front equalled dash and rear equalled front doors.
Do you have the stock deck? If it's aftermarket, could be hooked up improperly.
Another idea- maybe your "trim" only came with two speakers the dash and nothing else??
Old 01-25-2007, 05:57 PM   #9
davidcraig2003
There is an aftermarket cd player. The original tape deck still exits, with the cd player below it. However, its a Toyota cd player (well, Toyota branding) which would lead me to believe it was factory-installed. So it might be more than the wiring if it was installed officially
Heatshrink not working :| jmew0ng In Car Entertainment + Electronics (audio / video / alarm) 13 08-19-2006 11:26 AM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
