Old 09-04-2011, 12:52 AM   #1
Dpudg
Dpudg's Avatar
Drives: 2007 Toyota yaris sedan s
Headlights
So I had a close call the other day while driving my car, I couldn't see a bog box in the road at night due to my fading headlights, so I decided to get new bulbs, the ones I got are a pure white 12v 60/55w with 5000k, and after driving around I was curious and felt the headlights, I was surprised with how hot they were. Is 5000k too hot for the headlights? I don't wanna sound dumb, I know headlights get hot, but I guess I never felt them after use, any knowledge and if the new lights won't be a problem would be awesome.
Thanks much
Dpudg is offline   Reply With Quote
Old 09-04-2011, 01:25 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Your headlights can take a surprisingly amount of heat. If it's just the face of them that's hot, it's fine. Consider that when you're driving you're actively cooling them with wind.
Old 09-04-2011, 02:20 AM   #3
Dpudg
Dpudg's Avatar
Yeah I figured that driving cools them, just wanted to make sure that I wasn't gonna have to spend 150$+ on new headlights, thanks
Old 09-04-2011, 02:54 PM   #4
RedRide
RedRide's Avatar
The 5000k refers to the "color temp"..... that is just the color not the heat temp of the/a bulb.
A 3000k bulb will run just as hot as a 5000K bulb.
Al modern headlight bulbs like halogen quartz run hot and the headlight enclosures are designed to acomodate these higher temp.
Old 09-04-2011, 02:58 PM   #5
vten
You should've gotten the hid kits since it's so cheap nowadays ... Try to keep it around 4-6000k so u won't loose any lumen lights , and the hids usually run cooler than the regular bulb ... Just my .02 cents
Old 09-04-2011, 03:18 PM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
^ Even so.. anything above 5000 just looks.. BLUE. Like, TOO blue.
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
Yaris HB headlights bambam28 Cosmetic Modifications (Exterior/Interior) 1 09-03-2011 08:43 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
