Old 09-05-2011, 01:01 AM   #1
CAyaris
CAyaris's Avatar
Send a message via MSN to CAyaris
coilover help asap!
Hey can anyone that has coilovers, and knows how to do the installation on them please message me or call me asap; i need help with my install 623 203 9146
Thank you!
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 09-05-2011, 01:21 AM   #2
Shouldn't it be the same/identical to regular spring installs aside from the rear spring perch?
Old 09-05-2011, 02:29 AM   #3
Are any directions posted anywhere?
Old 09-05-2011, 03:13 AM   #4
CAyaris
CAyaris's Avatar
no instructions.
and the anti sway bar link is not able to attach because of the brake line
Old 09-05-2011, 09:45 AM   #5
It's drivable without the end links attached, so don't stress over that too much.
Where's the install pics so we can help?
Old 09-05-2011, 02:40 PM   #6
CAyaris
CAyaris's Avatar
the endlink wont go from top to bottom and when it does the car cant turn with out snagging the brake line
Old 09-05-2011, 03:10 PM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I assume your car is on stands when you took that photo.
Mount your wheel back on the car, tighten the lug nuts enough so your wheel doesn't fall off. Lower your car with a jack on the frame so the tire rests on the ground. You can raise or lower the jack to get the endlink into that hole.
Old 09-05-2011, 03:14 PM   #8
CAyaris
CAyaris's Avatar
No thats not the issue i just took the picture with it out, i can get it in but when i turn the wheel the brake line jams into the endlink
Old 09-05-2011, 04:28 PM   #9
Brian
Brian's Avatar
Did you unbolt the brake line and try re-routing it? You can also try some stainless lines which might give you a little more length to keep it out of the way.
Old 09-05-2011, 04:33 PM   #10
CAyaris
CAyaris's Avatar
yeah i had to unbolt it to move it to the coilover.
Old 09-05-2011, 05:40 PM   #11
CAyaris
CAyaris's Avatar
Anyone...? Really nt sure why its doing this? i have it in but it hits the line. And i cant drive like that....
Old 09-05-2011, 08:06 PM   #12
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
stock: (from a thread on here)
The mounting hole apears to be about the same distance from the tube. ....but, the end link looks more straight up and down in your picture. Is it the stock sway bar?
Old 09-05-2011, 09:17 PM   #13
CAyaris
CAyaris's Avatar
yes stock sway bar.
The Coilover Thread Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 294 02-23-2025 01:20 PM
COilover help, choosing right one CAyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-25-2011 02:18 PM
coilover sleeves mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 07-25-2010 06:13 PM
Is it possible to add coilover sleeves to tokico blues with tein s-techs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-22-2010 03:03 PM
D2 coilover deadcrow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-10-2010 01:32 AM
