Old 09-12-2011, 06:35 PM   #1
Roth5150
Drives: Yaris 2003
Post Handbrake Loose
Hi,
Could any of you tell me how easy is it to adjust the handbrake on 2003 Yaris. When I first pull up the handbrake it doesn’t hold the car sufficiently and if on a slight incline it begins to roll. I have to then pull the handbrake up to it’s highest possible point to have any effect. Is it possible to tighten the handbrake.
Thanks for any advice
Roth
Last edited by Roth5150; 09-12-2011 at 06:42 PM. Reason: Didn't say what Year of car
Roth5150 is offline   Reply With Quote
Old 09-12-2011, 09:03 PM   #2
vten
There's the bolt under the handbrake lever, you should see it connect to a steel wire ... If I'm not mistaken, u should tighten it clockwise ... And test it afterwards ..
Unknown plug under handbrake o.molina1 DIY / Maintenance / Service 1 01-29-2011 01:35 PM
how to break loose pulley bolt yaris9876 DIY / Maintenance / Service 10 05-16-2010 01:55 PM
Had my brakes done....now handbrake is harder to pull. captainm27 General Yaris / Vitz Discussion 7 05-10-2010 07:00 PM
Loose shifter knob dvspindler Cosmetic Modifications (Exterior/Interior) 7 08-06-2009 04:07 PM
Auto trans : Drive to Park + Handbrake : was not in park... Maxh91 General Yaris / Vitz Discussion 7 06-11-2009 06:37 PM
