Old 09-14-2011, 08:21 PM   #1
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
What was your first subcompact?
I've been going through old boxes lately and I've found all sorts of things I thought I had lost. Most importantly, I finally found a picture of the first cars I modified. It was still bone stock when I bought it in '88. It didn't stay that way for long
It was a '76 Civic 1500cc, 5 speed manual with the option gauge package (Tach added, Temp and Fuel gauges were relocated to a separate bezel in the dash.).
After killing the original 1500 (ED-3 I think), I stuffed an engine out of an '83 Prelude into it. (ES-1 with the duel carbs). It mated right to the original '76 5-speed and the original motor mounts. A slight modification to the original flywheel was about all that was needed. Exhaust was 2.5" with an 18" Cherry Bomb somewhere near the middle with the core knocked out of the Cat. I up-sized to 13x6" wheels and better tires and removed unneeded weight. It scaled at 1380 lbs, stock was a little over 1500 lbs. For a car its size, with the original close ratio trans it was scary fast in a straight line up to about 95 and even scarier in corners of any kind (70/30-ish weight balance). And of course, flat black paint with an offset white stripe.
I miss this car, one of these days I may try to reproduce it with a modern FI engine.
Pic is from '91 or '92
Stove is offline   Reply With Quote
Old 09-14-2011, 08:51 PM   #2
Klink10
Klink10's Avatar
That's one I wish I had. My first was a VW Bug. Then a 76 Corolla which I really do wish I still had.
Old 09-15-2011, 03:37 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
ohh.. 89 crx dx bone stock, just needed a clutch when puchased.
first car I bought in '99 i think..
biggest mods was:
integra gsr motor swap
had a t3/t4 turbo at one point but took it off when i started autocrossing
these pictures are 8 years old
-Derrick-
Old 09-15-2011, 08:01 AM   #4
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
1991 chevy SPRINT TURBO. It couldn't stop for shit and had no 4th/5th gear which made it a in-town car. This thing could burn out for days in second gear with ebrake up.....
Old 09-15-2011, 10:14 AM   #5
A-Dingo-Ate-My-Baby
Drives: yaris
1983 Renault R5 Turbo. 100% sick. Couldn't afford to keep it, but laid
rubber on every street in Austin TX when I had it. Replaced
with a regular LeCar afterward which matched my income better.
Got it from an Air Force pilot (I was an E3 in the same squadron) and
had it for 1 year.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 09-15-2011, 03:14 PM   #6
SailDesign
Drives: .
One of these - Mine was a 56, bought it in 72. Fine piece of ... rust. But it ran. Had semaphore indicators (very cool).
This chassis and engine were the donor car for the first Austin-Healey Frog-Eye sprites. Wish they looked as cool.
http://en.wikipedia.org/wiki/File:Black_Austin_A35.jpg
Old 09-15-2011, 03:21 PM   #7
SailDesign
Drives: .
Followed by one of these. In Violent Yellow.
http://img2.netcarshow.com/Fiat-126_...llpaper_04.jpg
File Type: jpg Fiat-126_1972_800x600_wallpaper_04.jpg (145.7 KB, 37 views)
Old 09-18-2011, 11:11 PM   #8
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
A-30... One of the guys dropped a 1275 into one of those; only external giveaways were tires and exhaust pipe. Man, that lil beast ate more Camaros than was legal!
My subcompact was a Ford Prefect; 30 raging gerbil-powered, it ate all the insects that were too slow to get out of its way. Mechanical brakes, poured-babbit rods, what a horrible POS that thing was...
