Old 09-27-2011, 10:17 AM   #1
A-Dingo-Ate-My-Baby
Drives: yaris
How much of a tire stretch is this ? no big deal ?
going to mount 185/60 R15 (7 inch tires)
on 7 inch rims
the Michelin recommends 5.5-6.5 inch rims for this tire and this size.
How much of a stretch is the extra 1/2 inch going to be ?
I am thinking it is not going to be an issue whatsoever.
Any opinions ?
I know TireRack will not let you order a mount and balance tires/wheels on a combination
that will be unsafe, and via the web they will spec the same 7inch rim size and tire
combo for the Yaris and mount and balance them. So...I am thinking...not an issue...
(I did get the actual wheels and tires from someone other than TireRack)
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 09-27-2011, 10:38 AM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
it really isnt much of a stretch at all. I seen people with old school toyotas that have baby supras (14x7) use 175-185 width rims all the time. Thinking of going old school style and using +10 offset rims? lol.
Old 09-27-2011, 11:26 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yea.. not that bad. only reason why its considered unsafe is the possiblities of riding on the sidewall under extreame hard corners. Used for looks and not performance.
-Derrick-
Old 09-27-2011, 12:01 PM   #4
33OH
Drives: '08 Yaris
Not a stretch at all, go for it.
Old 09-27-2011, 04:23 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
185mm tyres can safely fit wheels from 4.5-7.0
Old 09-27-2011, 05:52 PM   #6
A-Dingo-Ate-My-Baby
Drives: yaris
thanks for all your replies
Old 10-04-2011, 07:14 PM   #7
A-Dingo-Ate-My-Baby
Drives: yaris
this stretch reduces the diameter by a few percent
it translates to: actual speed 70 mph displayed speed 72
odometer miles lost...about 7 or so miles per tank
I have a scangauge and needed to tweak speed offset.
no big deal
Old 10-06-2011, 07:15 PM   #8
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
One other thing that tires that fit properly to the wheel do that is overlooked and those that autoX will tell you the same is they give you notice of the point that they are going to break loose.....stretched tires give little to no notice that they are gonna break loose in a corner and next thing ya know you are sideways and hating life.
Stretched is for looks and that is about it.
Old 10-06-2011, 08:53 PM   #9
SAV912
Pirate Yaaaaris
SAV912's Avatar
How is 7" wide tires on a 6.5" wide rim a stretch? It's not. That half inch won't make much a difference, and it should be fine.
Now if you came on here and said you want to put 5.5" tires on a 7" wide rim...that's a different story. And one that I don't personally condone for daily driving duties.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 10-06-2011, 09:14 PM   #10
A-Dingo-Ate-My-Baby
Drives: yaris
it is 7 inch tires, which Michelin recommends 5.5 to 6.5 inch rim for
I have a 7 inch rim...so that is 1/4 inch per side of stretch. not much at all,
and now that they are installed, it is a good fit
these are 60 aspect ratio, there is still tons of sidewall and I still have sidewall bulge.
skid notification has not been compromised
Old 10-07-2011, 01:57 AM   #11
SAV912
Pirate Yaaaaris
SAV912's Avatar
I read it backwards. My bad. It still looked worded awkwardly, 7" tires on 7" rims but then the recommendation for 6.5" rims. I doubt 7 on 7 will be even noticable.
-C
Georgia Bulldogs!
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire Wear Analysis Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-13-2009 09:28 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
