#1 |
![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
changing fuel filter
07 hatch 1.5 manual
I got the bottom seat out and I see the round spot welded port with the 3 wire coming out of it. I assume this is the fuel pump wires/no????? Do I pop off the rubber grommet to find the fuel filter down in there???? what is the best source for a fuel filter /aftermarket for this and any tricks for getting new one in???? thanks |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
FYI: i have NO listing for a fuel filter NOR do i see one in my catalog pictures.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#3 |
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
The 2007 Service Literature is linked here.
http://www.etimago.com/yaris/repairmanual/ You may want to look at the Fuel System part. |
#4 |
Toyota only sells the fuel filter attached to the pump. Beck/Arnley makes a replacement for the OEM filter and Rock Auto sells it for $20:
http://www.rockauto.com/catalog/x,ca...,parttype,6200
#5 |
i popped the grommet and only see wires......where is the fuel pump and filter on the hatchback??? anyone done this??
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
Its part of the pump. Its considered a non serviceable item. There should be no need to change it unless its clogged and causing low fuel pressure.
#7 |
This post has a pic of it (1st pic). You have to remove the top of the gas tank (2nd picture) to pull the sender unit out. The pump is mounted inside of the sender and the filter is clipped to it.
http://www.yarisworld.com/forums/sho...90&postcount=3
#8 |
so you have to pull the tank down...what a bunch of shit...
#9 |
No, you don't drop the tank, You remove the access panel inside of the car, and then remove the top of the tank and pull the sender unit out the top.
I pulled my tank when I got at mine because I was doing a little welding back there and didn't want to risk lighting the tank on fire.
| Fuel filter replacement | jaimico | DIY / Maintenance / Service | 43 | 03-07-2023 11:05 AM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Fuel Filter | abbeyaris | General Yaris / Vitz Discussion | 35 | 03-22-2009 11:40 AM |
