Old 10-04-2011, 05:28 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
new brake pads up front
I am about to do a front pad replace. Never have done one ever. Is there anything I need to know before I get into it??? I got new basic pads from Oreilly.... There is some shims in there too for whatever reason....
info pics..??? 07 hatch 1.5 manual
yaris9876 is offline   Reply With Quote
Old 10-04-2011, 09:16 PM   #2
yaris9876
got it done...very easy... FYI sticky you dont need to loosen bottom bolt if your only changing pads.... the bottom bolt is a bolt/nut....not a screw bolt like on top. the bottom
is a pivot and only needs to come off if your replacing rotors...you will 2 wrenchs for that one. and loosen cap on brake fluid reservoir before you press piston back with C clamp.
That way air can escape if there is any.
OEM pads from Oreilly were 22 bucks.
Old 10-04-2011, 10:27 PM   #3
Klink10
Klink10's Avatar
Glad you got it done and thanks for the tip.
Old 10-06-2011, 07:19 PM   #4
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
slowly push in the piston,the seal in the master cylinder can pull off its seal was what was told to me before I did mine....I dont know if this is comman but both my buddies who are mechanics both told me this when I asked if there was anything I should worry about.
new front brake pads yaris9876 DIY / Maintenance / Service 0 10-03-2011 09:12 PM
OE brake pads Jason@SportsCar Items for Sale by private party 1 04-25-2011 08:28 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
